• 26.09.2018, 16:54
Advice Installation fans and pump
Dienstag, 12. Juni 2018, 21:55
Hello, I have a Aquaero 5 PRO and a MultiSwitch USB. I am currently changing my equipment and I would like to have to control the EK-XTOP DDC 3.2 PWM pump with 12 fans ML120 with my equipment.
The 12 CORSAIR ML120 PRO fans will be connected via 2 Hub XSPC PWM et connect to the entry PWM from l'Aquaero, can I connect directly to the Aquaero 5 PRO by a Y-splitter for 4-pin fans (https://shop.aquacomputer.de/product_inf…roducts_id=3735).
And for the EK-XTOP DDC 3.2 PWM Elite pump, I will put only 1 pump (The power must be supplied directly from the PSU) with the cable connection cable for Laing D5 und DDC
Or I have to buy a Aquaero 6, but this is not the same bubget.
Thank you for your help
