• 15.12.2019, 02:04
_AK_
Tuesday, August 6th 2019, 6:03am
When you try to download Aquasuite X4 and install after reinstalling Windows 10, an error occurs.
The server was unavailable last night.
I ask you to drop me the installer, I can not configure my system because of this!
mditsch
Tuesday, August 6th 2019, 8:16am
you can download it here:
https://aquacomputer.com/software.html
_AK_
Tuesday, August 6th 2019, 9:18am
This error occurs after downloading the installer using your link. Otherwise, where would I get the print screen, which is in the post above ...
Dundys
Tuesday, August 6th 2019, 4:58pm
Try changing Time Zones or check your current time. For the first time ever I had this happening also and nothing would work until I started changing Time Zones, try it, it might work
bojer
Friday, August 9th 2019, 9:28pm
D5 Next showing as some USB device. Can you fix this? Thanks.
bojer has attached the following image:
Thursday, November 14th 2019, 2:49pm
Version X7 (insider) with many bugfixes is online.
Version X8 is online and fix some issues from X7.
Friday, November 15th 2019, 1:49pm
mhmm, my version X7 (insider) does not show X8 update as available (insider is checked). Guess I will manually download it.
Still hoping you are working on implementing push notification to the Windows Notification service for those of us who minimize on startup.
Friday, November 15th 2019, 2:29pm
You can also use the dowloader to install the aquasuite.
Friday, November 15th 2019, 3:12pm
Downloader?
I went to https://aquacomputer.de/software.html to download the update.
My version X7 was not aware of an update, so no downloading option was given in the aquasuite.
Am wondering If I was the only instance, or if others also did not have their X7 version detect X8 availability?
Friday, November 15th 2019, 10:33pm
My X7 didn't notify me of X8 until I rebooted my PC. It showed X8 available then
Downloader?
Tuesday, November 19th 2019, 9:46pm
Hello. I have farbwerk nano. And on version X6-x7 the audio analyzer works fine. But on X8 they any sound exist in system it shows only 2 small bars for left and right channels. See picture 1. On previous version was a lot of bars under the main sound selector menu. See picture 2. So for now my spectrum analyzer doesnt work. What can be a problem?
mditsch
Wednesday, November 20th 2019, 7:01pm
[attach]7071[/attach]
[attach]7072[/attach]
Are these two services running?
softlion
Wednesday, November 20th 2019, 7:12pm
Aquasuite X8:
it've just installed it.
After install the CPU of the AquaComputerService.exe process is 50% and stays at 50%.
X6 worked perfectly.
Plz bug fix asap.
UPDATE
I found a way to fix the issue:
- quit acquasuite
- open acquasuite in admin mode (run as administrator)
- stop the acquasuite service using acquasuite/service/stop button
- start the acquasuite service using acquasuite/service/start button
It won't take 50% CPU anymore
This post has been edited 1 times, last edit by "softlion" (Nov 20th 2019, 7:31pm)
Monday, November 25th 2019, 8:07pm
Yes. Now i'm on X6 and everything works but not on x8
Hopper64
Wednesday, December 4th 2019, 2:15pm
Tried Installing X.9 without success. It simply comes back to version X.8. Uninstalled the whole software suite, rebooted, downloaded the installer to X.4 and updated which brought me to X.8 even though X.9 is available.
Wednesday, December 4th 2019, 2:52pm
Try ist now again.
Hopper64
Wednesday, December 4th 2019, 3:06pm
Try ist now again.
Yes. That fixed it. Thanks!!
