Sie sind nicht angemeldet.
																														![]() Maki911
																		Maki911
																														![]() smud
																		smud
																														![]() smud
																		smud
Hi there, I've ordered MPS fill level sensor delta 500, and I was wondering how in the H to connect that in my loop. google didn't help and manual also huh.., forum search wasn't fruitful. Can somebody just tell me what fittings,connectors etc I need to buy and where to put it? Thanks in advance!
I was wondering, can I install that fitting for the lowest part of the reservoir to the side of the D5 top?
																														![]() chnh0453
																		chnh0453
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »chnh0453« (2. Mai 2020, 00:29)
May i ask one more question, if my reservoir only has ONE port on the top which for water in and i have no more port for Pressure equalisation membrane at the top of reservoir, what should i do it if i still want to setup MPS fill level sensors? Does the T fitting at the top of reservoir will work?
Thank you
