• 05.04.2020, 09:55
PSA for Splitty4
Thursday, March 26th 2020, 4:34am
If you have one of the very few Splitty4s that has Fan LED control issues, it may be due to a solder issue with the Pico Blade RGBpx input terminal. The Pico Blade terminal is very small with closely spaced solder points which on occasion have developed a solder bridge. A visual inspection of the back of the PCB would confirm the issue.
If there is a bridge, you can simply break it, and the Splitty4 should work properly.
This post has been edited 1 times, last edit by "InfoSeeker" (Mar 26th 2020, 4:35am)
