Sie sind nicht angemeldet.
Zitat von »back2Weihnachten«
I dont think there will be aquagrafx's for these cards...
Because there weren't aquagrafx's for the 5700/5600 series, and if AC would have planned some, they would have released them together wiith the aquagrafx6800...
Zitat von »Beun«
The 6600GT old :
it's as new as you can get... I personally would also like a solution for the 6600GT![]()
Zitat von »SantaClaw«
But the 6600GT just became avalible to the market, and the 6800\6800 ultra has been avalible for e few months...
Also, the 6600 GT is a MUCH better card than 5700\5600 ever was.... it's a lot faster than both x600 and x700....
Sure, it is better, but AC produces the aquagrafx/gratx series just for the highend class, and the 6600 GT is designed for Mainstream.
(Sorry for my English...)
), and fitted a twinplex block, the computer barely booted, a LOT of artifacts... The ramsinks was so hot they burned my fingers when I tutched them..
There is one, and it's true, the memory doesn't need to be cooled...
It works quite good, when a case fan blows over the memory chips...
BTW, I want a fanless pc, that is without any fans at all, (I've got two 120 mm fans, just to get some circulation) other than those two fans, Papst @ 20% normal speed, I havent got any fans, and I sure as (guess) don't want to install any more of them...
2 Papst should be enough...
But, you need a good radiator if you want it fanless...
Zitat von »avalon.one«
I ran my 5800 Ultra without any flaws just using a twinplex waterblock for gpu.
At the moment im using a twinplex and little memory heatsinks to cooldown my 6800 gt. I believe u will not needed anything bigger for a 6600gt card.
mfg, avalon.one
