Sie sind nicht angemeldet.
Percivul
Percivul
- connect the single end of THIS splitter to the aquaero 6 XT aquabus port
- then connect one end of two of THESE or THESE cables to the double end of the splitter from step one
- then connect one each of the two cables to one each of the two MPS Flow 200 aquabus ports
- start the aquasuite and go into each of the MPS flow sensor's settings tabs, and make sure each one has a different bus address.
1. Ok, so the single end goes to the flow port on the XT controller?
2. Seems straight forward.
3. So there's 2 sensors on the MPS that I need to connect? Which two would those be?
4. Not sure how to check or change the bus address. Is there something in the Aquero software that does this or is there a guide I can follow?
Thanks for responding so quickly.
Percivul
- no, you are communicating over the aquabus, the single end of the splitter goes to the aquaero AQUABUS port, you do NOT use the aquaero Flow port for MPS
- not really
- I thought you had two MPS flow sensors because you said "I'm reading zero for flow rates on both of the sensors."
If you have only one MPS sensor, you can skip the splitter and connect the aquaero aquabus port to the MPS aquabus port directly using either of the single cables I linked- unfortunately I do not have an MPS sensor on my machine so I cannot provide an MPS specific screenshot
I do not remember if the MPS flow sensor gets it's own tab on the main menu when using aquabus only, or if is under the aquaero tab.
IF you have only one MPS device, you do not need to worry about setting the address, the default will do.
OR, if you use the MPS USB port and connect it to a USB port on the motherboard, you can forgo the aquabus entirely.
Percivul
No, you have to use the aquabus high port. The flow port can be only used for simple 3-pin flow sensor that have no aquabus interface like this one for example.
This is a bit confusing. I understand that you have two sensors and want to use both of them simultaneously, right? As already mentioned by InfoSeeker you have to use a y-cable to do that. The single end goes to the aquabus high on the aquaero and the twin-ends go to the sensors (one connection per sensor).
The sensors must be connected via USB to see their device menu in the aquasuite software. You will see two mps entries in the left navigation bar. Check the system tab of both mps entries to make sure that the sensors use the latest firmware. The aquasuite will tell you if an update is required. In the system tab you can also change the aquabus ID of the sensors. Each sensor requires a unique ID so you have to change it for one of the sensors. Afterwards I recommend to turn off the PC completely. Turn off the power supply for a few seconds or unplug it from the power socket.
When you start the PC again you should check the aquabus tab of the aquaero. It shows all detected aquabus devices. You should see two mps devices.
Megalamaniac
You need to connect the MPS200 to USB so that you can configure it and set the aquabus address via aquasuite. Once you have done this you only need to connect the aquabus with 4 pin cable. You can use Y cables to connect more devices to the aquabus.
If you leave the USB cable connected with the aquabus connected, then you can use a 3 pin cable for the aquabus connection. Remove the USB and you need the 4 pin connector, and only the 4 pin cable
The device needs to be powered with 5v, which it gets from USB, or the 4th pin of the aquabus. If you have both connected it gets power from the USB, whether or not you have used a 4 or 3 pin cable for aquabus ( you CAN safely have both USB and 4-pin aquabus cables connected).
The low aquabus connector on Aquaero 6 has been converted, via firmware, into a 3-pin flowmeter connector for mechanical or passive flowmeters, not MPS devices.
Percivul
Well, I did what you guys suggested and connected the USB side of things first. Got a heartbeat. So while I don't have the 4 pin, it at least now shows up in the software so I thank you guys for all the help.You need to connect the MPS200 to USB so that you can configure it and set the aquabus address via aquasuite. Once you have done this you only need to connect the aquabus with 4 pin cable. You can use Y cables to connect more devices to the aquabus.
+1![]()
