• 27.04.2024, 23:46
Connecting Octo & Farbwerk to a single USB 2.0 header?
Mittwoch, 12. August 2020, 04:20
Both the Octo and the Farbwerk use half-size internal USB connectors, so is it at all possible to run both devices from a single header?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Netherspark« (12. August 2020, 04:23)
Mittwoch, 12. August 2020, 07:34
Every device need an USB Port. Normaly the Mainboard connectors have 2 USB Ports @ the 10/9 Pin USB headers. You can connect 2 Devices to this headers.
Mittwoch, 12. August 2020, 08:34
Yes, you can connect two 5-pin internal USB to one 9-pin motherboard USB.
