Vous n’êtes pas connecté.
Asryan
it's kinda annoying to have the fan speed changing all the time... I Ce message a été modifié 9 fois. Dernière modification effectuée par "Asryan" (28 août 2020, 23:09)
Asryan
I don't have the water temps with my Arctic Liquid freezer, i can"t use it.You're on the right way.
But first of all, you selected bad source for fan control, CPU temp can have spikes and is bad as a data source for fans/pumps/etc.
You'd better rely on water temperature.
At least, to have CPU temp output more plain, use both Average(t) with more then 5 secs and Low pass filter.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Asryan" (31 août 2020, 12:57)
"Good values" is to select another source from CPU core temp to control your fans. Use water temp.Ok sorry it's a bit obscure for me, if someone can tell me what would be "good" values.
Also are all those services needed to run? thanks[attach]7714[/attach]
Asryan
Ce message a été modifié 1 fois. Dernière modification effectuée par "Asryan" (2 septembre 2020, 13:19)
