• 26.09.2020, 10:15
Monday, August 17th 2020, 1:08pm
try to install the lastest vcredist package from microsoft.
Have you installed the aquasuite into the default path:
Quoted
C:\Program Files\aquasuite
and all windows Updates installed?
Monday, August 17th 2020, 1:28pm
Thanks, yes I've installed into default folder. And .net 4.8 runtime package from the installer link to Microsoft site
Actually after installing the latest graphics drivers this fixed the issue. Don't know whether it was the graphics driver itself or the redist package installed along with the nvidia package.
This post has been edited 2 times, last edit by "rad" (Aug 17th 2020, 2:06pm)
henson0115
Tuesday, August 25th 2020, 11:10am
anyone else notice that the until you restart the service, nothing happens with the fans after x26, if i restart the service it works and its not all the time, appears random.
Tuesday, August 25th 2020, 12:43pm
Have you tried increasing the 'Start delay' in the aquasuite settings tab? start_delay.jpg
Hopper64
Thursday, September 10th 2020, 12:30am
Noticed the new X.27 version. I guess this is available for download since it’s not an insider. There is no date or version designation for the download. Does anyone know if this is correct?
Asus R6EE, Intel 10900X @ 5.0, EVGA 2080 Ti, Phanteks Enthoo Elite, GSkill F4-4000C18Q2-64GTZR, Asus ROG PG349Q, EKWB Magnitude RGB and Quantum Kinetic D5, Corsair AX1600i, Asus Strix Flare, Asus ROG Gladius II Origin
henson0115
Monday, September 14th 2020, 2:32pm
Have you tried increasing the 'Start delay' in the aquasuite settings tab? [attach]7688[/attach]
no will try this thanks!
actually tried x27 first, this makes it even worse, if i enable any of the hardware monitoring (tick the hardware monitoring boxes), the fans get stuck at like 1300rpm, if i disable all fo the options, they work again. i am also using hwinfo and i think its a clash with this.
now gunna try adjusting the start up delay
This post has been edited 1 times, last edit by "henson0115" (Sep 14th 2020, 2:36pm)
Tuesday, September 15th 2020, 1:13am
I, and many, use HWiNFO and I have never had a conflict related to it.
Hopefully delaying the startup will improve your user experience.
henson0115
Tuesday, September 15th 2020, 5:28pm
ive changed the delay to 2 seconds and so far so good, if i see any other similar issues i will adjust to 3 and so on. the monitoring conflict has subsequently gone away. very odd but at least its working as intended now! thanks again for the assist :)
henson0115
Yesterday, 6:28pm
gets a bit odder, every now and again randomly, the service needs a reboot after start up, else the fans will ignore the curve. once rebooted (the service) it all works fine.
