Du bist nicht angemeldet.
ae111James
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »ae111James« (6. Januar 2021, 18:34)
ae111James
Control fan speed according to water temperature. Pump speed doesn't affect water temperature, but it can affect how well cooling blocks perform. Good rule of thumb is to keep water temperature below 40C. Why 40? It is considered a safe number to stay below in order to minimize bacteria grow or tube disformation. With pump speed you need to experiment. It's fine to set the pump speed to a level you find it's cooling capability to be enough and not disturbingly loud. You can start with 50% speed with D5, and make adjustments from there.
If you want to calculate heat dissipation power, you can do that with multiple water temp sensor+ambient sensor but that isn't necessary in terms of fan speed or pump speed control. It's more of a "nice to know and monitor".
Hello everyone,
first of all, Happy New Year to you all
I'm almost done with my build and I was wondering if you guys can help me decide if buying additional temp sensors is needed.
My goal basically is to make my PC silent so I entered the world of watercooling.
Anyhow, here's my setup so far.Res(D5 Next) > GPU > 360Rad >CPU > 360Rad> Res
*Rads are in push/pull
*Fans are controlled by the Octo
*Farbwerk for a lil bit of bling bling![]()
What's the ideal pump & fan config?
Should it be based in water temp, ambient air or both?
*temp sensor placement advice
I've got 2 external air temp sensors and have no clue where to put em![]()
Should I also get inline temp sensors to be installed in the output of both rads?
Thanks in advance!
ae111James
"This will get you as many different answers as there are people"
My self, I use coolant/ambient-air delta. Ambient air temperature influences a radiators ability to control coolant temperature. For instance there are places in the world around the equatorial band that can reach 45C, or higher, and the radiator will not be able to take the coolant below ambient temperature, with only fans to transfer heat to ambient air.
In high ambient temperatures with fan control dependent on coolant
temperature only, the fans will be rotating full RPM at a point well
before they have an effect.
With the delta option, they will work as much as needed when useful.
What do you think is better? a sensor behind the rear exhaust fan or behind the front rad?
Generally one external/ambient sensor is sufficient.
Placement
can be anywhere outside the system where it will be least influenced
from heat created by the system (including radiated heat from
radiators}.
One is probably all that is needed, but if you
place one behind each radiator, you can use the hotest one for the
I do like purpose designed coolant temperature sensors, because tape in a 'hot' environment tends to fail over time.
