Du bist nicht angemeldet.
pneuma
Sonntag, 18. April 2021, 01:07
pneuma
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »pneuma« (18. April 2021, 20:13)
I'm using 8 calitemp sensors so yeah I do need the splitty9 ontop of the x4 and I have 5x farbwerk360s as well that can be connected via aquabus as well so yeah not sure what you mean how is that redundant? I'm gonna try to disconnect the x4 and see if the splitty 9 works then. And I'm well aware that you won't see the splitty 9 but you should see all the calitemp sensors that are plugged into it. I see nothing but one single aquabus hub and no calitemp sensors at all? I'll take some pictures of the setup so maybe someone sees something I don't. I don't need the rpm cable If it's going to be an aquabus hub Im assuming ?
This means you may have a MAXIMUM of four (4) Calitemp sensors on an aquaero... if you need 8 Calitemp sensors, you will need a minimum of 2 aquaeros.
- If used with multiple Calitemp sensors, each Calitemp sensor must be connected to an individual connector of the aquabus X4 board - do not connect two Calitemp sensors to the same connector using splitter cables!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (18. April 2021, 21:16)
pneuma
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »pneuma« (18. April 2021, 23:18)
Hufeisen
You cant.Edit: I do not know if you can stack aquabus X4s?
Hufeisen
So much wrong in these lines...Well i also have 3 power adjust ultra 3's so it has 2 aquabus connections as well ? Only 1 of them is installed currently so I'll plug more of the power adjusts in if that'll work for the calitemp sensors.
So I can't connect that many calitemp sensors to a splitty 9 I've gotten it to see 4 of them through testing but that's it I think. I'll just buy another aquaero if I need to, but I just thought I could connect 9 aquabus devices to a splitty 9 let's say I don't use the x4 and I just use the splitty9? I'll still only be able to connect 4 calitemp sensors ? But I'd I plug the other two power adjusts in I can use their aquabus interfaces I'm assuming ?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hufeisen« (18. April 2021, 23:50)
pneuma
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »pneuma« (19. April 2021, 03:37)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (19. April 2021, 04:34)
Got the aquaero5 in so should just plug in and work right? Should I make the 5 a slave to the 6? Just wondering how to go about adding the 5 properly to the mix. I'd like the 6 to have control of it that would be nice?
24.5. aquaero 5/6 LT expansion device firmware
As a special feature, aquaero 5/6 LT devices can be programmed with an expansion device firmware to be controlled as an aquabus expansion board by anotheraquaero 5 or aquaero 6 device. Programming the expansion device firmware will completely replace the original firmware and the device can not be used individually any more, all controlling and monitoring functions must be managed by the aquabus master device. The USB interface will be completely disabled and the de-vice will not be recognized by the aquasuite after programming the expansion de-vice firmware. Only the following connectors will be operational as an expansiondevice:
Two aquabus addresses (26/27) are available for aquaero controllers pro-grammed with the expansion firmware. The second address can be selected by placing a jumper onto temperature sensor input 8. Devices programmed as an expansion device can be reset to the full aquaero 5/6LT functionality by performing the procedure described in chapter 28.1. only.
- Fan output 1-4
- Temperature sensor input 1-4
- Flow sensor input 1
pneuma
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »pneuma« (22. April 2021, 20:12)
