Du bist nicht angemeldet.
kensaundm31
kensaundm31
Yeah thanks I finally realised I had to pull out the weird rubber thing and the bottom panel is just held in by that! But the problem is that the screw are so short that they don't even come out the other side of the thin plastic bottom! So there is nothing to attach the bolt to!The three countersunk screws (angled seat) go into the bottom plate from the top side. Washers + matching nuts go on the opposite side. The pump then presses on top of the silicone.
kensaundm31
Actually they are the m3s the others are m4 and they dont fit through. I think they've sent me the wrong screws or i've got this pack of screws from something else thinking they're from the D5. I bought all this stuff back in November 2020 when I though gpus and cpus and psus were a thing you could actually buyThe three longer bolts should go down through the plastic plate from the top, and then through the metal bracket, with the corresponding nuts going on beneath the bracket.
In the second photo you're using one of the four shorter bolts. Those are for attaching the bracket to the case.
cptninc
That's upside down and those are the wrong screws. That bottom plate should sandwich the silicone against whatever the other mounting surface is. The three longer screws with the cone heads should go through the plastic piece.Yeah thanks I finally realised I had to pull out the weird rubber thing and the bottom panel is just held in by that! But the problem is that the screw are so short that they don't even come out the other side of the thin plastic bottom! So there is nothing to attach the bolt to!The three countersunk screws (angled seat) go into the bottom plate from the top side. Washers + matching nuts go on the opposite side. The pump then presses on top of the silicone.
https://1drv.ms/u/s!ApDZ5zl1onU8gto0NNkiy8NAQQH4Cw
Anyway I'll just buy the screws myself. Thanks for the help everyone.
cptninc
kensaundm31
Thanks. Bizarrely I had the wrong bag of screws, they must have been the screws from the additional aqua mount I bought and they were literally not long enough. I ordered new screws but also found the screws that were originally supplied which work fine! So to answer the original question I'm dumb
- Use the circled screws.
- Flip the mount plate as noted.
- Remove silicone from pump.
- Mount silicone to mount plate.
- Place mount plate against the mount.
- Insert the circled screws through the mount plate and through the mount. The heads of the screws should be completely flush with the mount plate.
- Use a washer and a screw on the backside of the mount to hold the screw in place. The washer goes between the mount and the nut.
- Righty tighty, lefty loosey.
- Push D5 controller onto silicone.
[attach]8411[/attach]
[attach]8412[/attach]
! But to be fair I bought all this other stuff 7 months ago and only now just putting it together. -
