• 25.06.2021, 09:01
softlion
Saturday, June 19th 2021, 4:01pm
@Remayz thanks for your answer, so much noobiness in it
Remayz
Saturday, June 19th 2021, 5:07pm
il faut bien expérimenter ^^
You can simply use a "water temp" - "ambient temp" sensor (with a low pass filter if it varies too much)
For the fan curve to avoid having your fan speed jump, just set a curve like that for example, and tweak the base, and maximum speed depending on the temperatures you want for the water :
And since you have a flow meter, you could have some fun and experiment with your pump speed depending on how your loop is set up.
For this to work you would need a temperature sensor before, and after the rads, and have all the rads in series (no waterblock in between rads).
You can then measure the water temp difference between input and output of the radiators (in this example i made a virtual sensor of it).
With water flow value, and knowing the specific heat of water, you can create a virtual sensor to calculate the heat really dissipated by the radiators, in watts.
You can then play with pump speed and see what it changes in terms of dissipation.All you'll see is spikes when the flow increase suddenly... then as water in and out temps stabilize after like 10 seconds... the dissipation is the same, no matter what flow.
.. and it's a nice sensor to have in the dashboard :p
In the end, for the pump speed, you'd just want to set it to 100% and look at your GPU temp under load.
as you lower the pump RPM, the GPU temp will climb extremely slowly.. like maybe 1 or 2° when you're down to 50% speed... keep going down and there's a moment you will see it increases a lot faster. In my case for example, if i go below 40% the temperature shoots up by 10° quickly. so that's my lowest speed.
From there, either keep the pump speed fixed, or set a curve that doesn't go below that threshold.
That's just how i set things up, you'll have to experiment a bit to find good values that keep things cool and/or silent as you like
This post has been edited 1 times, last edit by "Remayz" (Jun 19th 2021, 7:57pm)
softlion
Saturday, June 19th 2021, 6:54pm
J'avais une explication détaillée mais ce forum est trop pourri il a enregistré ... et laissé que la 1ere ligne ...
Bon la vitesse de la pompe joue bcp sur la température instantané à l'endroit du CPU notamment pour les AMD.
C'est intéressant de l'accélérer quand il est très utilisé.
Mais aussi de la ralentir quand il n'y en a pas besoin pour diminuer le bruit. Ce qui est très important dans un environnement silencieux comme la nuit chez moi.
C'est pas la meme courbe que pour les ventilos, mais elle est quand meme utile.
Yes look at my graph i use one.
No, it's useless. The mean T° of the water is enough to drive the flow speed and fan speeds.
This post has been edited 1 times, last edit by "softlion" (Jun 19th 2021, 6:57pm)
Remayz
Saturday, June 19th 2021, 7:53pm
Si la pompe est bruyante, ouep, ca ne se discute pas ^^ ca dépend du modele, du montage, du boitier :)
That sensor is just used for the dissipated power measurement in my example, not for fan driving (i could integrate it into the dissipated power formula, but i also need it for display in the dashboard, so i made two :)
Water temp, or water dT over ambient is sufficient, for fans yes.
Sunday, June 20th 2021, 9:33pm
I accidentally updated to X39 yesterday and am also seeing auto-shutdowns throughout the day.
aquasuite logging activated (a-suite_set.jpg)
but nothing in folder (a-suite_logs.jpg)
Windows event log attached:
InfoSeeker has attached the following file:
  • event_log.zip (4.21 kB - 5 times downloaded - Last download: Today, 6:51am)
Monday, June 21st 2021, 2:22pm
Event log re aquasuite random shutdown first instance this morning.
Remayz
Monday, June 21st 2021, 4:03pm
Same deal. It may be an impression but i feel it may crash quicker if i leave Aquasuite opened at all times (the interface opened).
It may crash once a day for me, 2 at most.
Remayz has attached the following file:
Dundys
Tuesday, June 22nd 2021, 2:21am
X39 randomly crashes :(
This post has been edited 2 times, last edit by "Dundys" (Jun 22nd 2021, 4:35pm)
cptninc
Wednesday, June 23rd 2021, 12:54pm
Is the return of Nvidia power monitoring one of the updates in X.40?
Remayz
Wednesday, June 23rd 2021, 5:35pm
Well Aquasuite X.40 has been up all day without a single crash. i've kept the interface open since it made X.39 crash faster, but it seems to be working good now.
Wednesday, June 23rd 2021, 7:09pm
x40 will not start. Splash screen then nothing. How do I roll back?
Dundys
Wednesday, June 23rd 2021, 8:20pm
Unfortunately, you can't go back to earlier version, that's the downfall to aquasuite i guess. Try rebooting few times. aquasuite can be finicky and might need few restarts to work as it should.
This post has been edited 2 times, last edit by "Dundys" (Jun 23rd 2021, 9:46pm)
Dundys
Yesterday, 1:24am
X40... so far so good :)
k2viper
Yesterday, 9:14am
Is Nvidia power monitoring back in X.40?
Remayz
Yesterday, 11:10am
I don't see it. But it works through HWinfo
