Sie sind nicht angemeldet.
WinstonWoof
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Speedy-VI« (11. Oktober 2021, 19:28)
WinstonWoof
These are most definitely PWM fansI Googled the EZDIY Fab Moonlight fans and found them on Amazon. I think these are cheapo 3-pin DC fans - not PWM controlled, which is part of the reason that a 6-pack of them with an RGB controller only costs $50. The Octo is designed to control PWM fans only. The Octo product page states, "All fan outputs are only suitable for PWM fans with four-pole connection plugs and are protected against overload.". I think the aquaero is the only Aquacomputer controller that can control 3-pin DC fans. A 3-pin DC fan will spin no matter where you set the speed because it is always getting 12VDC power from the Octo PWM fan port. Aquasuite (AQS) will report 0RPM fan speed because the DC fan does not send a tach signal to the fan port (because there is no 4th wire).
https://www.amazon.co.uk/gp/product/B08LKRNJTS/
I'm only experiencing the issue with any of the EZDIY fans connected to Fan Header 1 (admittedly I havent yet tried the Arctics on there)
The EZDIY fans connected to Fan Headers 2-5 work exactly as expected
WinstonWoof
That's the bit I was worried about ;o)
OK my bad When I Googled the fans what I found on Amazon were DC fans. Your link is to PWM fans. Since they are PWM fans, it sounds like your Octo Fan Port 1 has a problem. I guess start and RMA. Good luck!
WinstonWoof
SO what I found when I was testing it was.What happens if you define your own curve controller on other channels, or set PWM to 0% manually?
With PWM fans there are different behaviors at 0% PWM, normally they go to 100% power, which would make the behavior of the fan on port 1 look normal for now.
I think that by taking the controller from port 1, the OCTO controls the other ports differently.
But that's just a guess that would have to be checked.
Translated with www.DeepL.com/Translator (free version)
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »WinstonWoof« (13. Oktober 2021, 00:49)
WinstonWoof
iris mark
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »iris mark« (18. Oktober 2021, 10:38)
WinstonWoof
Remayz
WinstonWoof
support@aqua-computer.de
if aquatuning doesn't ship to the UK, it may be best to go directly with AC.
WinstonWoof
WinstonWoof
