 31.10.2025, 08:06
31.10.2025, 08:06 Sprache ändern
 Sprache ändern
						 Registrieren
 Registrieren Anmelden
 Anmelden
											Sie sind nicht angemeldet.
																														 AwkaBear
																		AwkaBear
								Mittwoch, 27. Oktober 2021, 07:44
																														 AwkaBear
																		AwkaBear
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AwkaBear« (27. Oktober 2021, 21:54)
																														 Remayz
																		Remayz
 like.. carefully moving an incense stick or even a smoking cup of tea, like an inch from the unit, carefully going around and see if the smoke gets sucked somewhere.
																														 AwkwaBear
																		AwkwaBear
i don't know if it's the camera focal, the 24 pin cable behind the reservoir throwing me off... but to my eyes the leakshield seems to be sliiiiiightly slanted towards the fan.
With no bubbles or water movement in the reservoir, it has to be a leak somewhere around or in the leakshield unit.
The pressure is still so high it has to be massive. TBH, i'd try some ghetto leak findinglike.. carefully moving an incense stick or even a smoking cup of tea, like an inch from the unit, carefully going around and see if the smoke gets sucked somewhere.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AwkwaBear« (28. Oktober 2021, 06:30)
																														 Remayz
																		Remayz
																														 AwkwaBear
																		AwkwaBear
Ah yeah thats a good idea ill have to try it out.you'd have to let the smoke rise from the base of the reservoir, see if it gets pulled under the leakshield, towards the seal. whatever the pump does above, blowing it doesn't matter.
But the cap test can let you know at least if the loop is leak tight.
If nothing is dripping you can use the computer anyway. That's basically how it's done usually hehe
																														 AwkwaBear
																		AwkwaBear
Doesn't the leakshield have an auto vent valve that relieves any overpressure though? Cause the leakshield does its leak test by using vacuum.
*snip*
I'm thinking the only way to rule it out for sure is to replace it with a regular cap and pressure test the loop without the leakshield installed. If that holds pressure then the leak has to be the leakshield
For comparison, pressure test with the leakshield installed also.
|   | Quellcode |
| 1 2 | "Can I test a system with LEAKSHIELD for leakage with Dr. Drop? No. LEAKSHIELD is designed so that overpressure always discharges. This happens even when the system is switched off. The leakage test should be performed accordingly using LEAKSHIELD itself." |
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »AwkwaBear« (28. Oktober 2021, 23:18)
																														 AwkwaBear
																		AwkwaBear
																														 AwkwaBear
																		AwkwaBear
That sucks but at least the Leak Shield sort of did its job. How much coolant was down there? Did you just not see it earlier?
Sorry you have to go through an RMA. Good luck!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AwkwaBear« (8. November 2021, 06:23)
 English forum »
 English forum » NEW: LEAKSHIELD - the safest liquid cooling system in the world
											(14. Juni 2021, 09:00)
										 English forum »
 English forum » Leakshield fill not working at all and leakshield saying I have a leak yet there is no leak!
											(9. August 2021, 06:03)
										 English forum »
 English forum » How to  connect MPS fill level sensors in the loop?
											(16. Februar 2020, 16:58)
										 English forum »
 English forum » Which pressure sensor choose?
											(6. Mai 2015, 16:27)
