• 01.12.2025, 14:33
Praetorian
Leakshield install problems
Mittwoch, 24. November 2021, 19:12
Hello,
I'm having the following issues with the Leakshield:
When starting it seems like it wants to do a pressure test and then goes to ~130mbar and then drops to 54 or so. It maintains 54ish and then steadily starts climbing. (See Picture)
Aquasuite says: "Factory test with 50 ML test body".
I am simply trying to leak test the Ultitube/Leakshield/D5 Next itself to double check everything, and this is what I'm seeing. I had it hooked up to a radiator previously and I'm getting the same results.
Thanks.
»Praetorian« hat folgendes Bild angehängt:
»Praetorian« hat folgende Datei angehängt:
  • 20211124_100745.jpg (126,76 kB - 309 mal heruntergeladen - zuletzt: 15. November 2025, 19:26)
Mittwoch, 24. November 2021, 19:27
Your LEAKSHIELD is in Satus Release.
Have you configured the LEAKSHIELD yet?
You can find the configuration and the actions on the page "LEAKSHIELD".
Praetorian
Mittwoch, 24. November 2021, 19:29
I have yes, I don't have the pump connected or anything since it's just a leak test though. I updated the firmware and reset to factory defaults also.
Praetorian
Mittwoch, 24. November 2021, 21:23
Well I made it further. I don't know what it wants. It seems to be calibrating, but I have no idea what it is calibrating
Edit Help would be much appreciated, I'm hoping to be able to get this working without an RMA.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Praetorian« (25. November 2021, 04:25)
Donnerstag, 25. November 2021, 07:34
What happens when you set the LEAKSHIELD to Shield?
Donnerstag, 25. November 2021, 09:03
There went something wrong in the factory. The calibration process was not finished correctly. That can not be fixed by yourself and you will need a replacement device.
Please get in touch with us via e-mail and provide your full postal address and a phone number.
