Vous n’êtes pas connecté.
P.C.Zen
Not sure re. "Gen2 LED" I thought it probably meant ARGB rather than RGB. Just a buzz-wordy way of saying it...?...although, maybe it does refer to the type of LED?Sounds like you have a plan. I don't know anything about the Cooler Master Halo fans but they look decent. I still don't know what they mean by "Gen2 LEDs". Maybe they upgraded to a brighter LED. Static Pressure is not great at 1.6mm H20 but sometimes you have to trade performance for bling. I am guilty of installing Corsair QL120 fans on my Fractal AIO radiator, and they have even worse static pressure than the Halo, or just about anything else. They have been described as a circular LED strip that also blows a little air. If you want higher static pressure AND RGB, I think the best options out there in 120mm are the Artic P12 PWM ARGB (1.85mm H20, 12 LEDs) or the Corsair ML120 Pro RGB series (1.78mm H2O, but only 4 LEDs) or the ML 120 RGB Elite series (2.90mm H2O, 8 LEDs). If you are willing to forgo RGB or use Phanteks Halos Lux RGB fan frames, then Artic P12-PWM PST (1.85mm H20) or BioniX P120 (2.75mm H2O) or Phantek PF-120T30 (3.30mm H2O), or good ol' Noctua Chromax NF-A12x25 (2.34mm H2O). This assumes you can believe the manufacturer's specs. Noctua's performance is proven, and the Artic P1x series and the Phanteks are getting good reviews. I don't trust Corsair specs at all, for static pressure or anything else.
I could not find how many LEDs are in a MF Halo fan anywhere in Cooler Master's product pages or spec sheet. Just make sure that you don't exceed 90 LEDs on any one Splitty12 Active output and 200 LEDs for the entire Splitty12 Active. The Cooler Master website says they provide little latching clips to hold the stupid ARGB connectors together. It's good to see manufacturers addressing this issue. It would be better if they selected a better connector but I guess it's too late for that. I have no idea who chose this connector, for 12VDC analog RGB and ARGB (with one pin missing), but it was a terrible decision. Probably driven by price. Good luck!
Ce message a été modifié 6 fois. Dernière modification effectuée par "P.C.Zen" (24 janvier 2022, 12:14)
Remayz
P.C.Zen
This is the first time I've actually looked at RGB fans at all, because I have my go-to fans for pressure and silence, so I've not heard of "capellix"?I guess they did like corsair with their "capellix" LEDs, trying to launch another trend by giving as little information as possible on what it means :p
The EK RGB straps are really helpful. It's really a crap connector that RGB thing, but they manage to keep them together..
I can't wait for the new maglev vardars with theeir beefy connectors to get rid of all that crap! lol
P.C.Zen
Ce message a été modifié 3 fois. Dernière modification effectuée par "P.C.Zen" (24 janvier 2022, 22:58)
