Sie sind nicht angemeldet.
marcosscriven
Montag, 14. März 2022, 16:38
Grestorn
marcosscriven
I don't know what happened to you, but an update will never be offered if you're not entitled to use that updated version.
Did you unplug the device that has granted you the license? Maybe you have an USB issue that this device is sometimes not visible?
xCROv
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »xCROv« (16. März 2022, 02:09)
Is this true? I don't recall ever seeing an option to install an earlier version and have read multiple posts saying that you can't go back to earlier versions. Maybe that is only true if device firmware has been updated to a later version?but you should also be able to run the AQS installer and, on the intro screen, choose to reinstall an older version with which your devices are still compatible... in my case X.47.
WinstonWoof
The installer will show the dialaog as shown at the picture I have attached. You have the option to install the old version or buy the new licence.
If you have installed the new version you can install the old one with the installer again.
Maybe you haven't read the info at the dialog.
[attach]9312[/attach]
WinstonWoof
Adding the PURCHASE button and taking away the INSTALL button would certainly make it fool proof, although the note is pretty clear. Based on OP's experience I guess there is nothing stopping you from installing the new version even though none of your devices are licenses to run with it. IMHO, that should be changed so you have to purchase the update service BEFORE you can install the new version that requires it.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WinstonWoof« (16. März 2022, 23:32)
marcosscriven
We will consider to change the desing. Anyway you can still install the old version if you decided to install the newest version.
Also we have many customers who are installing the aquasuite before adding the devices. So we can not force them to buy a licence in front.
Otherwise many of them would buy who don't need to buy it due an active update licence at an device that is not connected currently. That would also be a trap.
So there is no purchase at this point of install that's why there is not "Buy" button.
marcosscriven
NO, you can upgrade, we wont block this.it simply doesn't allow you to upgrade.
You can install the new version and buy or assign your new key.
In every update window there is a warning if you need a new key. Also in the aquasuite.
WinstonWoof
A question just came to my mind,
If you keep making the same mistake and ignoring warnings, shouldn't the solution be to respond to warnings instead of making a fuss here and demanding a change in common practice?
You're not really going to expect the rest of the world, who don't have the same problem as you, to change so you don't have to, are you?
marcosscriven
OK I understand, personal responsibility is not a good concept, better to be taken by the hand and not have to think.
I see it a little differently, but the will of man is his kingdom ;-)
