Vous n’êtes pas connecté.
Tenno6
Ce message a été modifié 1 fois. Dernière modification effectuée par "Tenno6" (3 mai 2022, 19:57)
Tenno6
I don't use profiles and never have and the fans wont reflect changesI saw your new post expressing frustration that no one has responded to this post so I will give it a go.
This sounds like it could be a profile switching issue. Aquasuite X.45 introduced unlimited Profiles and rule based Profile switching with priority hierarchy. Is it possible that some condition is causing a different Profile to be activated? One where the Octo fan control is set to power preset? Have you confirmed that the Octo profiles are set up properly? Have you checked your Global Profiles and automatic profile switching?
If you are sure that an unanticipated Profile switch has not occurred, some more details might help like manufacturer and model number of the fans you have attached to it, the version of Aquasuite you are running, and the version of firmware the Octo is running. Are the fans each connected directly to an Octo PWM port or are there PWM splitters? Were there any Windows or driver updates immediately before this happened? Is the Octo USB cable plugged directly into a mobo USB2.0 header or is there an internal USB hub? Are there other Aquacomputer devices? What other USB devices are connected? Any new ones?
Since it has been working for over a year, they must be PWM fans. Since you can see the Octo in Aquasuite, the USB connection must be working. Have you tried completely shutting down, turning the PSU off, and pressing the power button a few times to drain any residual charge?
Remayz
Tenno6
lost for lost, i'd try uninstalling / reinstalling aquasuite, then going to the Octo System tab to reset it to factory setting and try to create a new fan curve, see if it works.
But still pop an email to aquacomputer support in the meantime, it takes a few days to get an answer so better get it started now in case the Octo needs to get replaced.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Speedy-VI" (9 mai 2022, 05:01)
