 31.10.2025, 09:30
31.10.2025, 09:30 Change Language
 Change Language
						 Register
 Register Login
 Login
											You are not logged in.
																														 sebastianer
																		sebastianer
								Wednesday, June 8th 2022, 7:18pm
This post has been edited 3 times, last edit by "sebastianer" (Jun 8th 2022, 7:23pm)
This post has been edited 1 times, last edit by "Speedy-VI" (Jun 8th 2022, 9:37pm)
This post has been edited 2 times, last edit by "Ytterbium" (Jun 9th 2022, 9:10pm)
																														 Remayz
																		Remayz
																														 sebastianer
																		sebastianer
This post has been edited 2 times, last edit by "sebastianer" (Jun 9th 2022, 8:56pm)
																														 Remayz
																		Remayz
																														 sebastianer
																		sebastianer
This post has been edited 3 times, last edit by "sebastianer" (Jun 10th 2022, 9:38am)
																														 Remayz
																		Remayz
'This post has been edited 1 times, last edit by "Remayz" (Jun 10th 2022, 11:22am)
																														 sebastianer
																		sebastianer
																														 sebastianer
																		sebastianer
This post has been edited 4 times, last edit by "sebastianer" (Jul 14th 2022, 12:42am)
This post has been edited 1 times, last edit by "Ytterbium" (Jul 15th 2022, 7:43am)
																														 sebastianer
																		sebastianer
This post has been edited 10 times, last edit by "sebastianer" (Jul 14th 2022, 11:24pm)
 . I recall a discussion about the temp sensor in the D5 Next not being accurate because it is influenced by waste heat from the pump electronics. I think an actual temp sensor in the flow path that is not inside the D5 Next is probably going to be more accurate. I am not sure if the temp sensor in the High Flow Next also has accuracy limitations.
OK I was mixed up. It was the sensor in the HFN that is affected by waste heat from the electronics. I thought it was the D5 next so thank you for correcting me.I recall a discussion about the temp sensor in the D5 Next not being accurate because it is influenced by waste heat from the pump electronics. I think an actual temp sensor in the flow path that is not inside the D5 Next is probably going to be more accurate. I am not sure if the temp sensor in the High Flow Next also has accuracy limitations.
It was discussed HERE.
The sensor in the high flow next appears to function acceptably with coolant flow, as the bias is overwhelmed by the coolant.
The issue is more in using the automatic external sensor calibrations
																														 Jacob
																		Jacob
								Wednesday, July 20th 2022, 1:58pm
Sebastian
							This post has been edited 2 times, last edit by "Jacob" (Jul 20th 2022, 2:00pm)
 English forum »
 English forum » Aquaero 6 Pro + High Flow USB Flow sensor
											(Feb 24th 2016, 12:13am)
										 English forum »
 English forum » Aquaero 6 - 2 PWM pumps and 6 fans
											(Jan 26th 2015, 9:53pm)
										 English forum »
 English forum » AMS 420 rad/res/pump flow meter question
											(Feb 9th 2015, 8:21pm)
										 English forum »
 English forum » aquaero5 xt
											(Aug 4th 2013, 8:56am)
 aquaero5 xt
