Sie sind nicht angemeldet.
andsoitgoes
Samstag, 16. Juli 2022, 07:12
andsoitgoes
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 |
Application: AquaComputerService.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.IO.FileNotFoundException at MimeKit.Utils.CharsetUtils..cctor() Exception Info: System.TypeInitializationException at MimeKit.ParserOptions..ctor() at MimeKit.ParserOptions..cctor() Exception Info: System.TypeInitializationException at MimeKit.MimeMessage..ctor() at g4ippcQeZpn5Dro5w6E.jRpN9MQTvlTNEX1IKC6+<Mail>d__39.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at g4ippcQeZpn5Dro5w6E.jRpN9MQTvlTNEX1IKC6+<OnNotificationEvent>d__27.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 |
Faulting application name: AquaComputerService.exe, version: 10.2.8221.26732, time stamp: 0x62c433b9 Faulting module name: KERNELBASE.dll, version: 10.0.22000.795, time stamp: 0x960371d1 Exception code: 0xe0434352 Fault offset: 0x000000000004474c Faulting process id: 0x1dd0 Faulting application start time: 0x01d898d31b032e74 Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: b4fbf36f-7538-4724-bc2f-83c4c797c6a2 Faulting package full name: Faulting package-relative application ID: |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 |
Fault bucket 2188215857619676168, type 5 Event Name: CLR20r3 Response: Not available Cab Id: 0 Problem signature: P1: AquaComputerService.exe P2: 10.2.8221.26732 P3: 62c433b9 P4: MimeKit P5: 3.3.0.0 P6: de1d040c P7: 3c7 P8: 0 P9: System.TypeInitialization P10: Attached files: \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.715d9063-2c09-48ed-9df1-f753b580ce18.tmp.dmp \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.e35fec79-ccd1-422f-84e1-49a5e2dab0d2.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.d2e05c16-98eb-44dc-9b4c-a1d7dd9bb982.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.48e25122-f78c-435a-b2fa-5de160c7a726.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.59346870-71e3-4352-b2cd-8db4f576762f.tmp.txt These files may be available here: \\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_AquaComputerServ_0fb99cb5b11c4b33fead791bc9993debb36bda4_c6d46dd0_d28b48a6-3a24-41d4-becf-0ccb2a8f344a Analysis symbol: Rechecking for solution: 0 Report Id: b4fbf36f-7538-4724-bc2f-83c4c797c6a2 Report Status: 268435456 Hashed bucket: 50457a28e0c95d99ae5e1aba954c2c08 Cab Guid: 0 |
Quellcode |
Quellcode |
Faulting application name: AquaComputerService.exe, version: 10.2.8221.26732, time stamp: 0x62c433b9 Faulting module name: KERNELBASE.dll, version: 10.0.22000.795, time stamp: 0x960371d1 Exception code: 0xe0434352 Fault offset: 0x000000000004474c Faulting process id: 0x4a00 Faulting application start time: 0x01d899776fad1168 Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: 3ebf2542-6707-4950-a7cb-a02465d33f89 Faulting package full name: Faulting package-relative application ID: |
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »andsoitgoes« (17. Juli 2022, 02:53)
andsoitgoes
Quellcode |
Quellcode |
Faulting application name: AquaComputerService.exe, version: 10.2.8221.26732, time stamp: 0x62c433b9 Faulting module name: KERNELBASE.dll, version: 10.0.22000.795, time stamp: 0x960371d1 Exception code: 0xe0434352 Fault offset: 0x000000000004474c Faulting process id: 0xf34 Faulting application start time: 0x01d89a19632a0169 Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: 738cca2a-77d1-43ac-a8c5-f3f29d925e83 Faulting package full name: Faulting package-relative application ID: |
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »andsoitgoes« (17. Juli 2022, 22:20)
andsoitgoes
andsoitgoes
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 |
Application: AquaComputerService.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.IO.FileNotFoundException at MimeKit.Header.Unfold(System.String) at MimeKit.Header.SetValue(MimeKit.FormatOptions, System.Text.Encoding, System.String) at MimeKit.Header..ctor(System.Text.Encoding, MimeKit.HeaderId, System.String) at MimeKit.HeaderList.set_Item(MimeKit.HeaderId, System.String) at MimeKit.MimeMessage..ctor() at g4ippcQeZpn5Dro5w6E.jRpN9MQTvlTNEX1IKC6+<Mail>d__39.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at g4ippcQeZpn5Dro5w6E.jRpN9MQTvlTNEX1IKC6+<OnNotificationEvent>d__27.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() |
Quellcode |
Faulting application name: AquaComputerService.exe, version: 10.2.8221.26732, time stamp: 0x62c433b9 Faulting module name: KERNELBASE.dll, version: 10.0.22000.795, time stamp: 0x960371d1 Exception code: 0xe0434352 Fault offset: 0x000000000004474c Faulting process id: 0x1b5c Faulting application start time: 0x01d89ba6f87d634b Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: 8fd0f29c-884f-4642-b0a2-ca16746f6e5a Faulting package full name: Faulting package-relative application ID: |
andsoitgoes
andsoitgoes
Quellcode |
Application: AquaComputerService.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.IO.FileNotFoundException at MimeKit.Utils.CharsetUtils..cctor() Exception Info: System.TypeInitializationException at MimeKit.ParserOptions..ctor() at MimeKit.ParserOptions..cctor() Exception Info: System.TypeInitializationException at MimeKit.MimeMessage..ctor() at n9DoI449ngJJk23m29W.FlK6lV4n3FIIIm8Gehv+<Mail>d__39.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at n9DoI449ngJJk23m29W.FlK6lV4n3FIIIm8Gehv+<OnNotificationEvent>d__27.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() |
Quellcode |
Faulting application name: AquaComputerService.exe, version: 10.2.8229.14146, time stamp: 0x62ce5d65 Faulting module name: KERNELBASE.dll, version: 10.0.22000.795, time stamp: 0x960371d1 Exception code: 0xe0434352 Fault offset: 0x000000000004474c Faulting process id: 0x187c Faulting application start time: 0x01d89bb622030441 Faulting application path: C:\Program Files\aquasuite\AquaComputerService.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: 3ac4531b-de65-4291-89de-87ebc0577723 Faulting package full name: Faulting package-relative application ID: |
andsoitgoes
try a clean aquasuite install with the setup. maybe this is an issue with your settings., sadly that fix didn't work.
andsoitgoes
WinstonWoof
I can confirm this, my X.55 also loses contact with the Aquasuite service when I trigger a mail.
Under background service, the service is still displayed as "The service is running".
After the first reboot as administrator I tried this again, the service continues to run , according to the display, and I can stop and restart it.
Any attempt to send a mail stops the connection to the service .
Mail provider is Strato
Translated with www.DeepL.com/Translator (free version)
