Vous n’êtes pas connecté.
lundi 11 juillet 2022, 22:50
Its more accurate to say that iCue conflicts with HWINFO. ICue conflicts with all sensor monitoring programs because Corsair refuses to use the proper global mutex's to properly queue sensor polling requests. It will conflict with HWINFO, AIDA64, CPU-Z, SIV, etc. IIRC, HWINFO will display a warning and ask you if you want to enable polling of iCue devices because of this problem. This is one of the reasons that I refuse to install iCue.from iCUE no, but using HWinfo you can.
Aquasuite can access HWinfo data, so you can get the power supply info from there.
But HWinfo also conflicts with iCUE so you will more than likely have to ditch iCUE to get that.
cptninc
mardi 12 juillet 2022, 16:09
I'm not sure of your intended use for the data, but in my experience, the data coming off of Corsair's PSUs is very unreliable. I've had almost a dozen of those now (HX1200i, AX1600i), and all of them have followed the same path of degradation: everything works great, then the data stops updating in iCue with no errors presented, then single data streams start disappearing altogether and sometimes reappearing, and then no data is available at all.I have a number of these Corsair modular psu which report temperatures, voltages on the rails, current on the rails, and you can
switch between single rail or multiple rails by software. It has a big fan built in that spins on demand. This is part of the Corsair iCUE usb based intelligent device line.
Any way I can get or make a Aquasuite sensor for the PSU from iCUE?
