 31.10.2025, 17:24
31.10.2025, 17:24 Change Language
 Change Language
						 Register
 Register Login
 Login
											You are not logged in.
								Wednesday, July 27th 2022, 12:05am
This post has been edited 1 times, last edit by "InfoSeeker" (Jul 27th 2022, 1:46am)
This post has been edited 1 times, last edit by "InfoSeeker" (Jul 27th 2022, 2:08am)
																														 cptninc
																		cptninc
Your water must be inexpensive. That 5LPM 24/7 would cost me about $1500 per month.to start, yes, or i can put a cooling tower outside.
The heat exchanger is rated
- Heat Transfer: 4.0 kW (13,600 BTU/hr) (@5LPM, Delta between inlets = 20°C)
- Design Pressure: 15kgf/cm2 (213 PSIG)
- Design Temperature: -100°C (-148°F) min, 200°C (392°F) max
- Number of Plates: 12
																														 WinstonWoof
																		WinstonWoof
Of course, if it drained into a garden or lawn, then it would be only about $300/mo. That's cheaper than air conditioning in the summer, but far more expensive than using outdoor air in the fall, winter, and spring.
																														 WinstonWoof
																		WinstonWoof
Forget about the cost, it's simply wasteful from an environmental POV
If the water goes directly into the sewer, I agree. If this is water which is going to get used for something else, however, then this is actually good from an environmental standpoint.
							This post has been edited 2 times, last edit by "WinstonWoof" (Jul 27th 2022, 4:25pm)
																														 Remayz
																		Remayz
no, but it depends where the water comes from :pYea with the droughts everywhere and water usage restrictions starting to kick in mid july, it kind of makes me itch :p
Well the OP is in Brooklyn. DO they have droughts there?
																														 cptninc
																		cptninc
								Wednesday, July 27th 2022, 6:54pm
trying to think of a valid scenario where you might have that much water flowing for extended periods of time and and also just when you want to use your PC ;o)
I've got a 300l aquarium.
Even if I did a 50% water change at 5LPM that's only half an hour....................
Hmm maybe I should use my PC to heat the aquarium
 English forum »
 English forum » high flow NEXT - The next generation of flow sensors
											(Aug 26th 2020, 11:17am)
										 English forum »
 English forum » High Flow Next - Can I use it with just USB 2.0 header or aquabus is mandatory?
											(Jun 8th 2022, 7:18pm)
										 English forum »
 English forum » Flow Meter (53068) Troubleshooting Help?
											(Apr 20th 2020, 3:55am)
										 English forum »
 English forum » Please help! Only getting tiny bit of water flow with Aquastream Pump.
											(Jun 20th 2009, 9:08am)
