Sie sind nicht angemeldet.
piotrkun
Dieser Beitrag wurde bereits 8 mal editiert, zuletzt von »piotrkun« (24. Oktober 2022, 19:16)
piotrkun
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »piotrkun« (28. Oktober 2022, 20:43)
piotrkun
Leaving more air in the tube and calibrating the virtual flow meter didn't help. Reading this forum, I have found many mentions that small pressure leak is normal. I've posted those leak tests so either the support could tell me that it's normal or someone who has leakshiled could tell me if their system behave the same. Just notice that those small pressure leakes happaned over 2000-3000 seconds.I'm curious how this goes for you. Hopefully, it is as simple as just leaving more air space inside of the reservoir.
I have entirely stopped using my LEAKSHIELD because of its false alarms. It seems like a flawed execution of a good concept.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »piotrkun« (25. Oktober 2022, 17:53)
piotrkun
The first thing I notice is that you have practically no air in the reservoir, but the LEAKSHIELD needs air to work properly, the less air volume there is, the more sensitive it reacts to pressure changes.
Have you calibrated the virtual flow sensor of the D5 NEXT and given the LEAKSHIELD as a flow sensor?
Is the system completely vented?
If the LEAKSHIELD is not holding pressure I would suspect that there is an air leak somewhere, does air visibly collect somewhere in the system when you have turned off the computer overnight and the LEAKSHIELD is in shield mode?
piotrkun
I just finished building the system, so I've been testing how does the pump speed affect the cpu/gpu temperatures and where the sweet spot is between performance and noise. I also had issues with the pump noise and vibration, that's why I have been playing around with the power levels a lot. I have installed "Watercool HEATKILLER® Tube - Decoupling Kit for Stand" today which solved all my d5 noise and vibration issues. Now I can run the pump at 100%, and It's still pretty quiet.
If I interpret this correctly you regulate your pump, why?
Made a totally fresh default configuration for leakshield, using ultitube 150 defaults + adaptive pressure
Then it would be quite helpful if you would post the configuration of the LEAKSHIELD, without that it is also hard to say anything.
status page of leakshield :
Then also a picture of the status page would be very interesting.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »piotrkun« (28. Oktober 2022, 20:45)
piotrkun
I've fixed that already before by lowering the minimum pressure to 325 in the configuration. I've done a fresh default configuration to showcase the problem to you and removed my configuration changes from affecting the results.You do realize that the LEAKSHIELD has very little headroom with these settings?
At 100% pump speed and 375 mbar pressure from the pump, the LEAKSHIELD inevitably reacts very quickly, since the system can only be protected with an overpressure above 375 mbar.
Since the flow rate values do not help you, I would rather go to a value around 100 l/h, then the pump generates a much lower pressure and the LEAKSHIELD has more headroom.
With the status page I meant the one in the Aquasuite under LEAKSHIELD.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »piotrkun« (25. Oktober 2022, 18:58)
piotrkun
Ah I understand, but the real problem here is that leakshield is not reaching the set pressure because of this dip during setup. This is the real issue here. It can easily pump up to 440 during the leak testing and there are no drops there. Set point pressure is set to 425 and that should have worked perfectly fine.You don't understand me, the pump generates a pressure of 375 mbar, as soon as the vacuum drops below this value your system is not protected, I can't say exactly how much vacuum is necessary, but if you are only protected up to let's say 385 or 390 mbar vacuum there is not much left.
With these settings, the LEAKSHIELD makes little sense and will certainly give you no pleasure.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »piotrkun« (25. Oktober 2022, 19:14)
piotrkun
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »piotrkun« (25. Oktober 2022, 19:26)
