Sie sind nicht angemeldet.
The AZZA case looked a bit empty at the apex, so I added a glass prism rotated by a small 12V MOTOR. It can be seen at the end of this short CLIP.Very strange, especially the current draw wiggling around like that. What is a Crystal Motor?
Yes, the pumps are in series. I believe there are many who run two pumps in series, so I suspect that should not be a problem.are the two pumps in series?
i was wondering if maybe turbulence or whatever would make one more unstable than the other.
Never really used pumps powered from the PWM port otherwise.
Remayz
More than 3-4A.
Even with a 2A rush at start-up
Remayz
the 12V from the PSU isn't a straight connexion from the molex to the PWM ports. it goes through the driver chip which has a maximum rating.. the molex pins on the PWM ports are also rated to 2 - 2.5A max depending on the wire gauge attached. They too are overloaded when the pump starts up or accelerates.
It's a lot easier and safer to use a Molex splitter to power the Octo and two pumps direct from the PSU
Remayz
the poweradjust is a DC controller. it's just completely different from the Octo, and would only make sense for old DC controlled pumps, or if you really want to get it toasty by not using PWM on the pumps, which would make no sense since it will piss out power as heat for nothing... and you'd need one poweradust per pump. Constant 12V straight from PSU plus PWM control is a lot more efficient.
But for a PWM D5, it's understood that you power from SATA or Molex since that's what's attached on the pump. No PWM controller is made to directly power PWM pumps.
Any electric motor has high starting current, so when they say power can go up to 23W in use (~2A), you know the startup current is much higher than that. The documentation can't account for all the possible DIY use cases. The poweradjust being made to power pumps, it states in its manual the maximum continuous power, and maximum short term load. The Octo doesn't.
That aside, is there a reason why you don't want to use the original Molex plug to power them? even on a Mora you can find ways to hide a cable splitter to power an octo and two pumps.
Remayz
Finally you get to my point, lack of documentation. I felt comfortable running at 50% of rated capacity (pump_stats.jpg)My point was either one doesn't know electrical too well, and plugs things as they are designed to be used, or one knows and looks for the required info to DIY safely. If you have to assume, don't. That's how devices pop.
*sigh*
I still have no idea what the max current is for a D5, but AIO ports on motherboard, with their pretty weak pumps, are already rated to 3A. So it would make sense that a big D5 takes more. That for example could be a safe asumption and would trigger you not to connect a D5 to a 2A port.
If I had a D5 Vario (non-PWM), it would come with the standard 4-pin 5V/12V Molex connector. Where I to use a poweradjust, I would have to replace the connector to a fan style connector. So don't come at me as if I were breaking a rule because a different connector was installed. The name of this game is modification
I also don't know why you talk of the poweradjust then.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (19. Dezember 2022, 01:48)
Remayz
All i try to do is help solve issues. We can't change the documentation, but we certainly can try to make the installation better.-
