Du bist nicht angemeldet.
LiquidMX
Jacob
Uninstall the x86 Version in your x64 System
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Jacob« (14. März 2023, 10:35)
LiquidMX
unfortunatelly this didn't work at all for me , tested 3 times with same conclusion, installer cannot see .NET 7.0.3 installed .Uninstall all net 7 frameworks, net core, SDK.
reboot windows.
Install the correct desktop net 7 version.
Try install the aquasuite. These problems occur when you have a misconfigured window.
Hi,unfortunatelly this didn't work at all for me , tested 3 times with same conclusion, installer cannot see .NET 7.0.3 installed .Uninstall all net 7 frameworks, net core, SDK.
reboot windows.
LiquidMX
Thanks for that, installation wen't without problems and whole aquasuite running smoothly.We have updated the installer today.
There is now an option to ignore the Net Runtime check and install anyway.
But the Net 7 Runtime is needed, without it the software will not run.
Methodical
To confirm. Even though it was stated that Aquasuite would not run without the Net 7 Runtime, yours is working?Thanks for that, installation wen't without problems and whole aquasuite running smoothly.We have updated the installer today.
LiquidMX
