• 27.07.2024, 04:39
High Flow USB
Dienstag, 5. März 2024, 07:36
I seem to remember some years back I had the ability in the software for the High Flow USB to be able to change the impulses/rev.
Seems that is no longer possible. Was this removed for some specific reason?
Also is there some way I can send the data from the High Flow USB to the display of my Aquaero 6 without Aquabus? I feel like this should be an easy thing but I see no actual way to do it.
Dienstag, 5. März 2024, 09:07
you cant change the calibration, this value is fixed.
to forward the value to the aquaero, you have to connect the aquabus.
Dienstag, 5. März 2024, 15:58
Seem's odd to me that the calibration cannot be changed since my High Flow 2 is pretty much the exact same sensor in the mechanical aspect.
