You are not logged in.
This was an issue with the DataLogger.Email sent with ZIP. Previous version was X.79.
The database for the log data is corrupt.
Only a clean install will help.
This post has been edited 3 times, last edit by "gibsontk1" (Sep 18th 2024, 4:34pm)
Looks like I need to buy a new license key for both of my computers running Aquasuite. One of them only has an Octo installed. My main machine has a bunch of Aquacomputer products with update service expiration dates ranging from August 2021 to July 2024. After inputting the new license key, Aquasuite asks which device I would like to assign the new key to. Does it matter:? Is there any advantage to assigning the new key to the device with the oldest expiration date, or the newest expiration date? I don't think it matters, assuming I have no plans to remove any of the Aquacomputer devices, but figured there is no harm in asking.
I believe any one of their products will do, the aquasuite test for an active license anywhere.
I generally try to pick the device that would be most useful for a new build if my system cratered... i.e. octo over quadro, or if I have something on an external radiator.
Ditto, I normally assign mine to the Aquaero 6 XT but as Infoseeker says it doesn't really matter. @Shoggy I'm pretty sure that if said part did fail then Aquacomputer would honour the license?
Thanks to all. I bought 1 new license last night for the computer that just has an Octo. I updated that one to X.80 with no trouble and no virus warnings. I will update the main computer today.Normally the support team always finds a solution that everyone is happy with.
However, on the MQTT (RabbitMQ) side, I noticed a lot of "Unparseable MQTT packet" from Aquasuite:
Source code
1 2 3 4 5 2024-09-17 20:54:20.785746+09:00 [error] <0.17085.154> Unparseable MQTT packet received from connection 10.0.99.2:49990 -> 10.99.0.4:1883 2024-09-17 20:54:36.784055+09:00 [error] <0.17121.154> Unparseable MQTT packet received from connection 10.0.99.2:49996 -> 10.99.0.4:1883 2024-09-17 20:54:36.784435+09:00 [error] <0.17127.154> Unparseable MQTT packet received from connection 10.0.99.2:49995 -> 10.99.0.4:1883 2024-09-17 20:54:36.785318+09:00 [error] <0.17119.154> Unparseable MQTT packet received from connection 10.0.99.2:49997 -> 10.99.0.4:1883 2024-09-17 20:54:44.074874+09:00 [error] <0.17144.154> Unparseable MQTT packet received from connection 10.0.99.2:49999 -> 10.99.0.4:1883
This post has been edited 1 times, last edit by "Bartdude" (Jan 7th 2025, 6:50pm)
