• 11.11.2025, 11:42
um2802
High flow Next display issue
mercredi 20 août 2025, 09:59
Hi guys,
For about a month now, I've been having a problem with Next - the display.
I've attached pictures showing what it looks like.
I tried resetting it, unplugging it, but nothing worked, it's still the same.
What solution would I have to get it back to normal?
Thank you.
um2802 a envoyé les fichiers suivant :
  • IMG_0654.jpg (400,18 kB - téléchargé 50 fois - Dernier téléchargement : 27 octobre 2025, 14:24)
  • IMG_0655.jpg (290,1 kB - téléchargé 41 fois - Dernier téléchargement : 6 novembre 2025, 03:59)
  • IMG_0645.jpg (414,05 kB - téléchargé 40 fois - Dernier téléchargement : 1 novembre 2025, 18:19)
  • IMG_0647.jpg (472,19 kB - téléchargé 44 fois - Dernier téléchargement : 22 octobre 2025, 23:19)
  • IMG_0650.jpg (302,94 kB - téléchargé 70 fois - Dernier téléchargement : 23 octobre 2025, 05:03)
Remayz
mercredi 20 août 2025, 20:48
that looks like a classic case of burn-in. if it is the solution is very simple unfortunately : get a new one
maybe if it's still under warranty, it could be worth it to check if it's covered.
um2802
mercredi 20 août 2025, 23:48
Ugh, I didn't even think for a second that it could be burn-in :(
Do you have any idea if the display can be replaced, meaning if I can buy a new one and replace it?
jeudi 21 août 2025, 04:30
It's an OLED display and OLED displays suffer from burn-in. I don't know if Aquacomputer sells replacement OLED displays, or what is involved in replacing one.
I have a High Flow Next and a D5 Next. I keep the displays on them either off or on low brightness because of concern about burn in. I hope that someday Aquacomputer will release updated products with small, higher resolution color displays. They are not expensive. Here are some EXAMPLES of small color TFT LCD displays. TFT LCD displays the size of the monochrome OLED displays in Aquacomputer products cost less around $4, and less than that in bulk. Corsair uses IPS TFT LCD displays in their AIO CPU cooler blocks, and if they can figure it out, surely Aquacomputer can! My dream is a new Aquaero controller that consists of a high resolution full color IPS TFT LCD display tethered to a small box that contains a powerful microcontroller and all of the various I/O connectors. Maybe someday. In the mean time, I do my best to avoid OLED burn-in by keeping my Aquacomputer displays at low brightness, and off when idle.
Discussions similaires
