• 31.10.2025, 09:29
Information about Windows Defender warning "HackTool:Win32/Winring0" (AquaComputerService.sys)
Mittwoch, 12. März 2025, 11:47
Windows Defender and other antivirus software (repeatedly) detect the AquaComputerService.sys file as a threat or virus.
This is not a virus!
This file is a signed open source driver (WinRing0) that aquasuite has been using for many years for hardware monitoring (e.g. CPU temperature). The exact same driver is also used by numerous other, far more popular programs and companies.
A security vulnerability (CVE-2020-14979) has been known to exist in this driver for some time. The problem is that the driver lacks a security descriptor and can be accessed with user rights. Since the driver has deep access to the system, it is possible for malware to exploit the driver and gain system privileges to run malicious code.
Regardless of the version, aquasuite applies a security descriptor when installing the driver, which restricts access to system and admin rights. Based on current knowledge and our own tests, the mentioned attack scenario is no longer feasible.
Please note: If any other application installs the driver before aquasuite without a corresponding security descriptor, the driver is vulnerable. In this case, this is a failure on the part of the corresponding application.
We are already working on a solution by creating our own customized version of the driver and having it certified by Microsoft. However, this is a complex process and will therefore take some time. The main problem is the verification of our company in the Microsoft Partner Center. Microsoft switched this process to an AI-based system last year, and since then, nothing has been working properly. There are numerous reports of companies that had to wait several months before they were approved. Microsoft is aware of the problems and has been promising to solve them for months...
If you do not see any problems with using the driver, you can define it as an exception.
Alternatively, you can disable all hardware monitor modules in aquasuite via the aquasuite -> Service tab. This will prevent aquasuite from loading the corresponding driver. System data can still be transferred to aquasuite via HWiNFO or AIDA64 if required.
Donnerstag, 9. Oktober 2025, 08:16
Update on the current status (October 9, 2025):
We have developed a completely new driver with a stricter security model.
Unfortunately, it is currently unclear how long Microsoft’s certification process will take.
The aquasuite X.84 setup now automatically adds an exception for the monitoring driver in Windows Defender.
This setting is enabled by default but can be disabled during installation if desired.
Due to differences in security mechanisms across Windows versions, Windows 11 may still display warnings about temporary driver files.
This does not affect monitoring, which remains fully operational.
Freitag, 10. Oktober 2025, 03:38
The aquasuite X.84 setup now automatically adds an exception for the monitoring driver in Windows Defender..
Congrats on getting the new driver written and submitted to MS for certification. Is adding the exception to Windows Defender the only change in X.84?
Freitag, 10. Oktober 2025, 10:01
The way how the hardware monitoring driver is processed has slightly changed. A wrong translation in the RGBpx controller context menu was fixed and some features of the RAM hardware monitoring have been removed since they caused crashs on some systems.
camjo99
Defender triggers even with exclusion - Workaround - C:\Windows\SystemTemp\
Dienstag, 14. Oktober 2025, 02:54
Happy to hear you guys are working on a new driver!
In the meantime, I recently started getting defender notifications every time I woke up my PC. Both from full shutdown or just sleep.
This is even though I already have "C:\Windows\System32\drivers\AquaComputerService.sys" excluded in Defender.
If anyone else is facing the same, read on. I found a decent work around to use until the new signed driver is available!
Upon system resume, Defender alerts on files with names that look like this:
C:\Windows\SystemTemp\UDDC168.tmp
There is always multiple files, and always inside C:\Windows\SystemTemp\
The filenames always start with UDD but the latter digits change, so excluding these files in Defender doesn't help.
You could exclude all of C:\Windows\SystemTemp\* in defender, but this felt overly broad to me - so I started digging with Process Monitor, and tracked down what was creating these files.
As it turns out they are being created by pcasvc - a component of windows. This is the Program Compatibility Assistant Service
This service Checks for legacy application behaviors or crash data, and can create temporary .tmp or .etl (event trace log) files.
For some reason, at least on my system, this service was tripping up on AquaComputerService.sys on every boot - Maybe assuming the driver is having an issue on resume.
(now that I type that out, this makes sense. When I first put together this rig I had to manually create a custom task to restart the aquasuite service 30s after any "workstation unlock". I have never had the service properly resume after sleep mode, I would always lose HW monitoring data)
So, as soon as pcasvc sees whatever issue happen, it must be extracting the winring0 driver (or a part of it) and creating an error/dump file inside C:\Windows\SystemTemp\
This then gets picked up by defender, as I did not have this path excluded!
So - instead of excluding the whole SystemTemp folder in Defender, The workaround is to block pcasvc from reading AquaComputerService.sys
This can be done like so in an administrative command prompt:
Quellcode
1
icacls "C:\Windows\System32\drivers\AquaComputerService.sys" /deny "NT SERVICE\PcaSvc":(R)
This will add an ACL entry to deny the service from reading the file. And if it can't read it - it can't copy it to SystemTemp!
This resolved my issue and I don't get a defender popup when I wake from sleep anymore.
If anyone else is having this issue - hopefully this helps while we wait for the new driver! :)
Here's hoping the new driver will natively handle wake from sleep better as well...
RE: Defender triggers even with exclusion - Workaround - C:\Windows\SystemTemp\
Mittwoch, 15. Oktober 2025, 22:57
Interesting. I wonder if this is related to the constant stream of Catalog DB errors I have been seeing in C:\Windows\System32\catroot2\dberr.txt since the day I updated Aquasuite to X.83. Here is a LINK to my post detailing my observations about the behavior of the AquaComputerService.sys driver file on my main Windows 10 machine. Strangely, my other machine also running Windows 10 had totally different behavior. I never did figure out why, but I am still getting these errors on my main Windows 10 machine. Here is a partial screenshot of today’s errors. I never got any response from Aquacomputer about this.
The entries look like this: CatalogDB: 8:29:43 PM 9/14/2025: catadnew.cpp at line #1977 encountered error 0x800700c1. This error (0x800700C1 = ERROR_BAD_EXE_FORMAT) normally means Windows rejected a malformed or unsigned driver file. Based on timing, I suspect it’s related to the AquaComputerService.sys driver. Do you know if there is a way to stop these errors from being logged?
rays2c
Freitag, 17. Oktober 2025, 21:05
I think because of this, the aquacomputer service no longer starts automatically on bootup. Is there something I need to do to enable the autostart of the aquacomputer service on bootup?
Antikythera
Dienstag, 21. Oktober 2025, 09:45
Thanks for the information on this issue. I appreciate the candor. Also interesting information on the process.
I was wondering if once the fix is implemented will it be applied to older versions or will I need to purchase the update service?I'm running version X.44
Anti
edit: but holy crap, the autoformatting of this forum software after i hit submit, sucks. lol
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Antikythera« (21. Oktober 2025, 09:53)
