Sie sind nicht angemeldet.
Zitat von »Weihnachts-Shoggy«
A few people had the problem that the tubemeter is showing a too high fill level. The new firmware fixes this problem.
You can download firmware 1.06 here.
You have to connect the tubemeter to a USB port if you want to flash it. Close all unnecessary applications, start the Aquasuite and flash the downloaded file.
After flashing the tubemeter it will log on to USB again; if not you have to shutdown your pc (off) and start it again.
Zitat von »Top_Nurse«
So is there some kind of circuitry inside the Tubemeter casing? Or does the flash procedure just update the Aquasuite software?
Zitat von »Beun«
Is it possible to flash when attached to the aquaearo?
