Sie sind nicht angemeldet.
Zitat von »SNIFFER«
A_L,
what flow rate are you getting there out of interest.
Also you mention temp software using compu-nurse. No idea what that is, could you explain that more to me,
Thanks
SNIFFY.
Zitat von »richard.docksey«
just in case it's of interest to anybody who was following this thread...
the temp I reported at the beginning was probably wrong - there seems to be some nuances in measuring amd64 x2 core temps, and the utils I used at the time (hmonitor/everest) either weren't up to it or I wasn't up to configuring them
I now use "core temp" which (from what I can tell) does the job well.
unfortunately, I changed my setup (essentially what I had before + an additional 360 rad) so can't report what this utility would say about the temps before this change... but, for what it's worth, my temps are now reported at (approx) 28-31C idling and 32-38C under various loads. though I can pretty much control this to stick around 31/32C switching all my fans on max.
and the room temp is around 23/24C.
I haven't scientifically measured these temps, it's just what I notice now as I keep an eye on them a lot now.
I hope to measure the water temp soon, but can't decided if I should by an aquaero or not.
Richard.
