Vous n’êtes pas connecté.
1.) doesn't matter.
2.) yes, that's correct.
3.) I think nobody can answer this. If you have an older version you can easily flash the newer one.
4.) you can use the aquasuite with both versions installed.
1.) Yes, that's possible. More at the next point
2.) Forget this link, you only want to update the firmware and not the whole OS. Within the aquasuite you click on Sprache and select english. This setting is also important because the firmware will be flashed in the language which is currently set. Click on aquaero -> flash firmware and point to the file aquaero firmware 410a.afd4. You will get a box with some bla bla, just cofirm it. When you start the update you have to press and hold the set-button on your aqauero for around 2-3 seconds. Than the flash process starts and when it is finished the display will show you a restart message. Shutdown your computer, wait a short moment and start it again. That's all
3.) Sure, go to the menu display & hardware and you will find a few helpful settings on the right side.
4.) No, it's only available in english.
5.) After point 2.) you will have to (re)configure your controlling settings etc. To store them in the memory of your aquaero you have to save it to the eeprom. If you won't do that you will lose all settings when the pc is shut off.
The LCD-Mode is necessary if you want to show other stuff on your display. For example via jaLCDs.
6.) I recommend that you save your default setting in a profile. If you flash a new firmware you can just load your settings and store them to the aquaero instead of doing it all over again.
Different profiles might be useful if you want to have a fast option to switch between "I want to overclock now, give me all your power!" or "I want to sleep now, so be quiet!"![]()
Citation de "Shoggy"
You have the wrong cable!
That cable is for the tubemter and not for the multiswitch. You only need a simple 3-pin cable like this one.
You connect it to the aquabus port of your aquaero and multiswitch.
Citation de "A_L"
Now with MULTISWITCH jumper#3 closed, the function now only with switching On/Off ?! ???
