Sie sind nicht angemeldet.
, if reboring and reversing the flowmeter increases the water-flow.
Zitat von »El_PResidente«
Hmm.. To be honest.. It could affect your flow.
I increased the hole in the Intake-Side of teh digmesa-flowmeter with a 6mm akku-drill. After that i reversed my flowmeter to have a accurate size (5,6 mm) that is on the out-take as the new intake.
It increased my flow from about 32 l/h to around 40 l/h with a eheim 1046. (Gaged with water before and after!)
The impulses per liter are 509 with 3,3 mm intake (digmesa-sheets) and afaik 279 with a 5,6 mm intake (Inreased an reversed). Based on the Digmesa-Flowmeter sold in the AC-Shop!
Yes, you're right. You need to set 256 Imp/l with 5,6 mm "Intake". Not 276! I checked it with the Digmesa-Sheets.
