 31.10.2025, 09:31
31.10.2025, 09:31 Change Language
 Change Language
						 Register
 Register Login
 Login
											You are not logged in.
Quoted from "Stefan"
Please ...
discussion and links only on AC blocks.
Quoted from "hobbes"
Also in germany the provider of a forum can be made responsible for the posted comments. So if anybody would start flaming on some manufacturers products, AC might get in trouble.
that's the way it is in Germany :-/
Quoted from "divve"
I may have missed it but I don't see the type of CPU you have? If it happens to be a quad core your planned set-up won't be able to keep your CPU under 65c during stress testing. IMO go with two loops with an 8800 SLI or get a 3 + 2 radiator and a bigger pump.
Quoted from "awelch"
Well if I were to run 6 AC water blocks would the pump have enough pressure to go through all 6? Also would the radiator be able to sufficiently cool that much heat?
also if the system would be able to go through 6 water blocks what would be the best order for them to go in? I was thinking:
rad > pump> cpu > gpu1 > gpu2 > spp > mcp > vreg > res >
would this be a good order?
