 31.10.2025, 09:32
31.10.2025, 09:32 Changer la langue
 Changer la langue
						 S’inscrire
 S’inscrire Connexion
 Connexion
											Vous n’êtes pas connecté.
Citation de "Stefan"
The prob is not the pump, maybe the rad .. and sure you can name the components, just make abbreviations.
most interesting part .. how big is the radiator and at what voltage the fans are running ?
Citation de "Top_Nurse"
Alternatively you can also drill out the stock AC flow meter, but then you would need to calibrate the flow yourself. The stock AC flow meter artificially limits the flow to about 80-90 LPH due to the tiny 3.3 mm hole in the intake side. If you are looking for the best flow then this flow meter mod is the way to go as the Inn... unit also has limitations on flow due to inlet size restrictions.
Citation de "divve"
I'll try that when I have to take my stuff apart again for the next gen GPU in Nov/Dec.. For easy calibrating I'll get another AC flow meter and stick it in the same loop as the one I have. Both the modded and stock version should essentially give the same readout after pulse correction. My guess is though that a bigger passage hole will increases the minimum flow reading threshold. So, instead of being able to read all the way down to lets say 8l/h it won't respond below 20-30l/h.
Citation de "divve"
My plan is to only use two flow meters in a test loop for the calibration process. When both stock and mod version have the same readout I'll know its calibrated properly...at least as good as the original that is...
