You are not logged in.
Quoted from "Shoggy@SILO"
Welcome to the forum
To use all features you should connect both devices to USB.
The pump comes with a 3-pin cable, it can be used to connect the aquastream XT to the aquaero via aquabus so you can read out some data or adjust the frequency.
Quoted from "Lil_Duck"
@Cobra88
Try to connect the 3pin connector from the aquabus port on your display to the rpm port on your aquastream xt. This should work! Good luck buddy
Quoted from "Cobra88"
not tried it any other way but still have no flow readings from my Aquastream XT Ultra.
