Vous n’êtes pas connecté.
god0815
Citation de "Chrizzz"
Dont do that! There is absolutely no reason for "creating" 2 Systems. HDDs are producing heat at around 5-10W. This is nothing. Just make one system an save some money at this part
The Evo240 will be enough and it will give you good (and quiet) temps, thats for sure!
speaking of noise: your PSU is probably another source! you should think about modding it with one large 120mm-fan at 7 or 5 volt or (since you appear to be quite wealthy... 5 aquadrives... pfuuh ) buy a watercooled PSU like the aquapower (which has a 230V-plug included) or the coolcurrent. both can be found in ACs shop
If you drop the 12V-Eheim pump from your budget and replace it with 2 1046 you could realise this system without exceeding your financial limits to much.
Citation de "Nightreaver"
...The AquaDrives are actually more for the noise than the cooling. But when warping up your harddrives heat is always an isue.
How's the pump's noise level? Are they virtually silent, as 2 would increase the total dB level.
Citation de "MojoMC"
Aquadrives are not very good in lowering the noise. Several people claimed about that.
The normal 230V Eheim 1046 is 99% noiseless as long as no air is in the pump. You should care about the vibration of the pump; if the pump is attached to the case to strong the case could make vibration noise.
Citation de "r1ppch3n"
ps:
sorry for my bad english![]()
--- 15" MacBook Pro Retina (2014) 2,8 GHz Quad-Core Intel Core i7 Prozessor (Turbo Boost bis zu 4,0 GHz), 16GB Ram, 1TB SSD, NVIDIA GT 750M mit 2 GB GDDR5 --- 13" MacBook Pro Retina (2014) 3,0 GHz Dual-Core Intel Core i7 Prozessor (Turbo Boost bis zu 3,5 GHz), 16GB Ram, 1TB SSD --- iPad mini "White", 64 GB Wifi --- iPhone 6, 128 GB "White" --- Apple TV (2012) --- Airport Extreme --- Time Capsule 2 TB --- Apple Rockt
erm...
actually the aquadrives do quite a good job calming your hdds down
what they NOT do is making them noiseless, but i doubt they would be much louder than the fans on the radiator (even if you use the silent papst fans)
btw:
i bet you won't describe the noise level of your psu as 'acceptable' when you find it being the by far loudest piece of hardware in your pc...
trust me, i know what i'm talking about :![]()
god0815
Citation de "god0815"
You can put your hdd's in aquadrives and then seal them in a sound-surpressing box stuffed with 'Schaumstoff' (?) That should take care of heat AND sound
I'm sorry to say that I'm not very impressed by the performance of my own aquadrive... You can still hear the disk...
