Vous n’êtes pas connecté.
Citation de "Koradhil"
MB 81°
Gehäuse auf + 40cm Ventilator !!!!!!
Au Mann
GRuß Koradhil
Citation de "friku"
H
1.) Substitute the 120 rad, with a double 120 (or triple one if possible in space and availability of money)
2.) Substitute the Eheim600 with a more higher pressure like pump. Blocks with jet design loves high pressure
3.) Change the position of the VGA card block, put it just behind the CPU block, because the Chipset would run perfectly enough with higher temps.
Citation de "Stefan"
1. a 120 Evo is enough .. no dream temps, but enough
2. the pump is alright no prob with the flow in such a small circuit
3. the position changes nearly nothing at all, because the water temp is balancing within the circuit +- 1 ° C
Die Grafikkarte ist doch gar nicht mehr das Problem ? Lest Ihr noch mit ? Die Northbridge ist das Einzige was noch zu heiß wird.
