Sie sind nicht angemeldet.
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 |
# coding=utf-8 import wx # wxPython import os # OS-spezifische Funktionen import cPickle class DropTarget(wx.PyDropTarget): def __init__(self, parent): wx.PyDropTarget.__init__(self) self.data = wx.PyBitmapDataObject()#wx.EmptyBitmap(width=100, height=100, depth = -1)) self.SetDataObject(self.data) def OnDrop(self, x, y): return True def OnData(self, x, y, d): if self.GetData(): # convert it back to a list of lines and give it to the viewer linesdata = self.data.GetData() lines = cPickle.loads(linesdata) self.dv.SetLines(lines) return d class DropSource(wx.Window): def __init__(self, parent): wx.Window.__init__(self, parent, pos=(800, 0),size=(350,600), style=wx.SUNKEN_BORDER) self.parent = parent self.lines = [] self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown) pdc = wx.ClientDC(self) pdc.SetBrush(wx.Brush('GREEN YELLOW')) pdc.DrawRectangle(0, 0, 90, 160) def OnLeftDown(self, event): self.StartDragOpperation() def StartDragOpperation(self): linesdata = cPickle.dumps(self.lines, 1) ldata = wx.CustomDataObject("DoodleLines") ldata.SetData(linesdata) bmp1 = wx.EmptyBitmap(90, 160) dc = wx.MemoryDC() dc.SelectObject(bmp1) bdata = wx.BitmapDataObject(bmp1) data = wx.DataObjectComposite() data.Add(ldata) data.Add(bdata) dropSource = wx.DropSource(self) dropSource.SetData(data) class W1(wx.Window): def __init__(self, parent): wx.Window.__init__(self, parent, pos=(0, 0), size=(90, 160), style=wx.SUNKEN_BORDER) dt = DropTarget(self) self.SetDropTarget(dt) class W2(wx.Window): def __init__(self, parent): wx.Window.__init__(self, parent, pos=(0, 290), size=(90, 160), style=wx.SUNKEN_BORDER) dt = DropTarget(self) self.SetDropTarget(dt) class Zeichnen(wx.Window): def __init__(self, parent): wx.Window.__init__(self, parent, pos=(10,20), size=(700,450), style=wx.SUNKEN_BORDER) #self.SetBackgroundColour(wx.WHITE) dt = DropTarget(self) self.Bind(wx.EVT_PAINT, self.OnPaint) def OnPaint(self, event): point = [((95,0),(95,450)), #senkrechte linie links ((605,0),(605,450)), #senkrechte linie rechts ((0,165),(95,165)), #1. waagerechte ((0,285),(95,285)), #2. waagerechte ((605,165),(700,165)), #3. waagerechte ((605,285),(700,285)), #4.waagerechte ((155,165),(556,165)), #waagerechte 4er block oben ((155,285),(556,285)), #waagerechte 4er block unten ((155,0),(155,165)), #senkrechte linien oben ((255,0),(255,165)), ((355,0),(355,165)), ((455,0),(455,165)), ((555,0),(555,165)), ((155,285),(155,450)), #senkrechte linien unten ((255,285),(255,450)), ((355,285),(355,450)), ((455,285),(455,450)), ((555,285),(555,450))] dc = wx.PaintDC(self) dc.BeginDrawing() pen = wx.Pen('WHITE', 9, wx.SOLID) for x in range(0,len(point)): pen.SetCap(wx.CAP_ROUND) dc.SetPen(pen) dc.DrawLines(point[x]) dc.SetBrush(wx.Brush('GREEN YELLOW', wx.BDIAGONAL_HATCH)) dc.SetPen(wx.Pen('WHITE', 1, wx.TRANSPARENT)) dc.DrawRectangle(96, 0, 59, 450) dc.DrawRectangle(556, 0, 49, 450) dc.DrawRectangle(155, 166, 401, 119) dc.SetBrush(wx.Brush('GREEN YELLOW')) dc.DrawRectangle(0, 0, 90, 160) dc.DrawRectangle(0, 170, 90, 110) dc.DrawRectangle(0, 290, 90, 160) k = 0 for j in range(4): dc.DrawRectangle(160+k, 0, 90, 160) k = k + 100 k = 0 for j in range(4): dc.DrawRectangle(160+k, 290, 90, 160) k = k + 100 dc.DrawRectangle(610, 0, 90, 160) dc.DrawRectangle(610, 170, 90, 110) dc.DrawRectangle(610, 290, 90, 160) dc.EndDrawing() class Raum(wx.Frame): #------------------------------------------------------------------------------ def __init__(self): wx.Frame.__init__(self, None, -1,"Raumplaner", (200,300), (1200,600)) self.panel = wx.Panel(self, -1, style=wx.SIMPLE_BORDER) vbox = wx.BoxSizer(wx.VERTICAL) sizer = wx.BoxSizer(wx.VERTICAL) #Erstellen der Toolbar self.toolbar = wx.ToolBar(self, -1, style=wx.NO_BORDER)#style=wx.TB_HORIZONTAL | wx.NO_BORDER) self.toolbar.SetToolBitmapSize((32,32)) self.toolbar.AddLabelTool( 0, 'Neu', wx.Bitmap('./icons/new_page.png'), wx.NullBitmap , wx.ITEM_NORMAL, 'Neu', 'Neues Element', None) self.toolbar.AddLabelTool( 1, u'Öffnen', wx.Bitmap('./icons/open.png'), wx.NullBitmap , wx.ITEM_NORMAL, u'Öffnen', u'Datei öffnen', None) self.toolbar.AddLabelTool( 2, 'Speichern als', wx.Bitmap('./icons/save_as.png'), wx.NullBitmap , wx.ITEM_NORMAL, 'Speichern als', 'Speichern als', None) self.toolbar.AddLabelTool( 3, 'Beenden', wx.Bitmap('./icons/exit.png'), wx.NullBitmap , wx.ITEM_NORMAL, 'Beenden', 'Beenden', None) self.toolbar.Realize() sizer.Add(self.toolbar, 0, wx.EXPAND | wx.ALL | wx.TOP) vbox.Add(sizer) vbox.Add(self.panel, 1, wx.EXPAND | wx.ALL, 0) self.SetSize((1200, 600)) self.SetSizer(vbox) #Erstellen der Statusbar self.statusbar = self.CreateStatusBar(2) self.SetStatusBar(self.statusbar) self.toolbar.Bind(wx.EVT_TOOL, self.OnNew, id = 0) self.toolbar.Bind(wx.EVT_TOOL, self.OnOpen, id = 1) #self.toolbar.Bind(wx.EVT_TOOL, self.OnSaveAs, id = 2) self.toolbar.Bind(wx.EVT_TOOL, self.OnExit, id = 3) #Erstellen der Menübar self.menubar = wx.MenuBar() datei = wx.Menu() work = wx.Menu() self.new = wx.MenuItem(datei, 000, '&Neue Etage\tCtrl+N', 'Neue Datei erstellen') self.open = wx.MenuItem(datei, 001, u'&Öffnen\tCtrl+O', u'Datei öffnen') self.worked = wx.MenuItem(datei, 002, 'B&earbeiten\tCtrl+B', 'Datei bearbeiten') self.save = wx.MenuItem(datei, 003, '&Speichern\tCtrl+S', 'Datei speichern') self.quit = wx.MenuItem(datei, 004, '&Beenden\tCtrl+Q', 'Programm Beenden') self.back = wx.MenuItem(work, 010, '&Neue Etage\tCtrl+N', 'Neue Datei erstellen') self.delete = wx.MenuItem(work, 011, u'&Öffnen\tCtrl+O', u'Datei öffnen') self.test = wx.MenuItem(work, 012, 'B&earbeiten\tCtrl+B', 'Datei bearbeiten') datei.AppendItem(self.new) datei.AppendItem(self.open) datei.AppendSeparator() datei.AppendItem(self.worked) self.worked.Enable(False) datei.AppendItem(self.save) self.save.Enable(False) datei.AppendSeparator() datei.AppendItem(self.quit) work.AppendItem(self.back) work.AppendItem(self.delete) work.AppendItem(self.test) self.Bind(wx.EVT_MENU, self.OnNew, id = 0) self.Bind(wx.EVT_MENU, self.OnOpen, id = 1) #self.Bind(wx.EVT_MENU, self.OnWorked, id = 2) #self.Bind(wx.EVT_MENU, self.OnSaveAs, id = 3) self.Bind(wx.EVT_MENU, self.OnExit, id = 004) self.menubar.Append(datei, '&Datei') self.menubar.Append(work, '&Bearbeiten') self.SetMenuBar(self.menubar) def OnNew(self, event): self.w1 = W1(Zeichnen(self.panel)) self.source = DropSource(self.panel) self.Centre() self.Show(True) self.worked.Enable(True) self.save.Enable(True) self.menubar.Refresh() def OnOpen(self, event): self.directory = os.getcwd() self.save = wx.FileDialog(self, u'Bitte Datei zum Laden wählen', self.directory, '', '*.txt', wx.FD_OPEN | wx.FD_CHANGE_DIR) self.choose_save = self.save.ShowModal() if self.choose_save == wx.ID_OK: try: wx.MessageBox("Speichervorgang erfolgreich!", "Info", wx.OK | wx.ICON_INFORMATION) except IOError, error: wx.MessageBox("Fehler:\n" + str(error), "Info", wx.OK | wx.ICON_INFORMATION) #def OnWorked(self, event): #self.dc1.Clear() #def OnSaveAs(self, event): #self.Close() def OnExit(self, event): self.Close() if __name__ == '__main__': app = wx.PySimpleApp() Raum().Show() app.MainLoop() |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 |
# coding=utf-8 import wx # wxPython import os # OS-spezifische Funktionen import cPickle class DropTarget(wx.PyDropTarget): def __init__(self, parent): wx.PyDropTarget.__init__(self) self.data = wx.CustomDataObject("DoodleLines") self.SetDataObject(self.data) def OnDrop(self, x, y): return True def OnData(self, x, y, d): return d class Room_draw(object): #-------------------------------------- def __init__(self, room_name, size): #----------------------------------- self.name_room = room_name self.size = size self.pos = (0,0) self.status = 0 def SetPosition(self, pos): #----------------------------------- self.pos = pos #Zeichnen der Räume für die Belegung def Draw_Room(self, dc): #----------------------------------- if self.status == 1: actPen_o = dc.GetPen() dc.SetPen(wx.Pen('black', 5, wx.SOLID)) dc.DrawRectangle(self.pos[0], self.pos[1], self.size[0], self.size[1]) dc.DrawText(self.name_room, self.pos[0], self.pos[1]) if self.status == 1: dc.SetPen(actPen_o) #Prüfen ob Raum ausgewählt def HitTest(self, x_pos, y_pos): #----------------------------------- if x_pos > self.pos[0] and x_pos < (self.pos[0] + self.size[0]): if y_pos > self.pos[1] and y_pos < (self.pos[1] + self.size[1]): return True return False def Select_Room(self): #----------------------------------- self.status = 1 def DeSelect_Room(self): #----------------------------------- self.status = 0 class DropSource(wx.Window): def __init__(self, parent_opl): #----------------------------------- wx.Window.__init__(self, parent_opl, size=(300,400), pos=(800,50)) self.Bind(wx.EVT_PAINT, self.OnPaint) self.Bind(wx.EVT_SIZE, self.OnSize) self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown) self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp) self.rooms_list = [Room_draw('W1', (90, 160)), Room_draw('W2', (90, 110))] #Position der Räume festlegen x_pos = 100 y_pos = 100 for room_each in self.rooms_list: room_each.SetPosition((x_pos, y_pos)) x_pos = x_pos + 100 self.dragRoom_o = None def OnPaint(self, event): #----------------------------------- dc = wx.PaintDC(self) dc.SetPen(wx.Pen('black', 1, wx.SOLID)) font = wx.SystemSettings.GetFont(wx.SYS_DEFAULT_GUI_FONT) dc.SetFont(font) # alle Räume darstellen for room_each in self.rooms_list: room_each.Draw_Room(dc) def OnSize(self, event): #----------------------------------- size = self.GetParent().GetClientSize() self.SetSize(size) def OnLeftDown(self, event): #----------------------------------- # wurde ein Rechteck getroffen ? x_pos = event.GetX() y_pos = event.GetY() for room_each in self.rooms_list: if room_each.HitTest(x_pos, y_pos): room_each.Select_Room() self.dragRoom_one = room_each else: room_each.DeSelect_Room() linesdata = cPickle.dumps(room_each, 1) bdata = wx.CustomDataObject("DoodleLines") bdata.SetData(linesdata) dropSource = wx.DropSource(self) dropSource.SetData(bdata) dropSource.DoDragDrop(wx.Drag_AllowMove) # neu darstellen self.Refresh() def OnLeftUp(self, event): #----------------------------------- if self.dragRoom_one != None: # Ziehen beenden self.dragRoom_one = None self.Refresh() class W1(wx.Window): def __init__(self, parent): wx.Window.__init__(self, parent, pos=(0, 0), size=(90, 160), style=wx.SUNKEN_BORDER) dt = DropTarget(self) self.SetDropTarget(dt) |
