• 28.04.2024, 12:00
Is there a way to remove quality control markings or rotate the pump casing?
Mittwoch, 27. März 2024, 19:46
My D5 Next with Ultitube arrived with a prominent quality control stamp on the front of the pump. Can this be removed, or can the casing around the pump be rotated to hide it? I don't want to rotate the whole pump because that would rotate the control unit, just the casing. So far I've been unsuccessful.
Thanks.
»JonnyK« hat folgende Datei angehängt:
Mittwoch, 27. März 2024, 20:04
Try isopropanol. Maybe it works. Never use Aceton or other aggressive chemicals. In some cases a normal rubber works fine.
Noname21
Mittwoch, 27. März 2024, 20:09
Hi JonnyK
Did you buy the pump new or second-hand?
If the pump is new, I would write to Aquacomputer. They will certainly be able to help you.
Mittwoch, 27. März 2024, 20:34
This is brand new right out of the box, Ultitube Pro with D5 Next. I splurged.
Donnerstag, 28. März 2024, 15:28
Vinyl Wrap?
Montag, 1. April 2024, 12:31
Hey hi, you may need to contact the manufacturer for specific instructions on removing the quality control stamp or rotating the casing around the pump without affecting the control unit.
