Sie sind nicht angemeldet.
Zitat von »Flying_Dutchman«
[klugscheiß]The right grammer would look like this: "Unplug all cables and lay your case on its back..."[/klugscheiß]
Sorry, ich weiß nich, was Klugscheiß auf Englisch heißt...
Zitat von »poly«
Thanks!
Figured the filling tip out within seconds after posting ;D
Another question:
Will the P&Q plugs work with silicone tubing with the same messurements?
-Hugo
Zitat von »KampfSchwein«
no way, jose!
only PUR-tubes... silicone is way to soft! your system would leak like a women during her period! ;D
Zitat von »454-bigblock«
Where are you from?
Zitat von »poly«
OK, I´ll probably order the stuff with 10mm hose plugs instead then. Not a big fan of L-plugs..
