• 17.07.2018, 01:39
Fan port #10?
Dienstag, 2. Mai 2017, 11:42
After I attached my old Aquaero 6XT as a slave (removed the display part and reset it to slave) a new fan port, #10, has popped up in Aquasuite - Aquaero - Fans. It shows up if the slave is connected or not. I have also installed a Farbwerk USB, but for the life of me I can't find any ports on it that could be used for fans. Under settings it looks like one of the ports I set up on the Aquaero I now use as a slave, like some sort of ghost (minimum power of 35%, which is the kick-in voltage needed for one of the sets of fans (used to be 8 fans, but with the slave connected I have reduced it to 4), but all fans are set to 0-100% now, so it's not one of them showing up twice.
