• 20.06.2018, 06:01
Aquabox ~ silly problem
Freitag, 25. Mai 2018, 14:18
Hi, I had just about given up trying to get the magnets to fit into the back of the reservoir sockets for the magnetised tray.
They really seem to be much too big to fit?
If anyone else has the same issue (I Phoned up Stefan Mai who gave this advice and he was right and very helpful).…
I put wood on the table to protect it, I placed the magnet over the hole
then pushed quite hard down onto the magnet using another wood block.
Using wood doesn’t make the magnet jump out of place.
There were no splits in the casing although the holes are close to the edge so you can be quite brutal as the Aquabox is tough.
Maybe these instructions would be useful on the website?
Regards. Brian.
