• 15.02.2019, 19:59
NEW: RGB Splitty3
Freitag, 29. Juni 2018, 11:14
RGB Splitty3
RGB Splitty3 is a distribution board for up to three single RGB LEDs for connection to a farbwerk controller or a compatible mainboard RGB connector.
The board can simply be inserted vertically into a suitable connector. The included RGB LED can be plugged in at the side. At the end of the board there is a connector to attach another RGB Splitty3 or an LED strip.
The included LEDs have a diameter of 5 mm and are suitable for illuminating many water cooling components such as aqualis reservoirs, aquatubes or acrylic versions of the cuplex kryos NEXT.
RGB Splitty3 is compatible with the Aqua Computer farbwerk and most mainboard connectors for RGB LED strips. Due to the arrangement of the connectors only channel #1 and #4 of a farbwerk unit can be used for RGB Splitty3.
RGB Splitty3 will be available at shortly at a price of 9.90 Euro. A RGB LED is already included in the scope of delivery.
