• 19.09.2019, 05:33
novax1
Aquastream Ultimate and Aida64 Android
Tuesday, December 11th 2018, 11:39am
Hello everyone.
First apologize if my explanation is not clear.
I have to translate
I bring you a topic of how to show information
Aquastream Ultimate in Android with Aida64 via Wifi.
Thanks a Odospace Member of Aida64.
If you have a mobile terminal with Android that
does not USA u can give utility displaying information of aquastream Last.
For me it's being very useful.
Explain download PlayStore The Apk In the terminal
you are going to use.
https://Play.Google.com/store/apps/details?id=com.odospace.remotepanel
It's free.
In this section of the Aida64 forum they explain
how.
https://forums.Aida64.com/topic/2776-display-PC-sensor-Values-on-Android-Device-Connected-via-USB-odospace-Remote-panel/
or follow my explanation
Have Aida 64 installed.
With this image I show it will be easier to
configure to put the IP and image size of the Android terminal that Hge a use,
in Aida64
1-Find the IP in the terminal, go to Settings,
System, about the device, status, IP address annotate the IP.
2-Open Aida64
3-In the Files tab. BNoscan external applications
and select all.
4-On the tab preferences look for LCD will open
another window there select Odospace.
In the first box put the IP of the terminal that
will use I have annotated Previously
5-In the same window you have to configure the
screen resolution of the terminal you are going to use.
6- The rest leave it as this I activate the check
box enable LCD support Odespace, with this the WiFi configuration I'd be there.
7-Go to LCD elements and there are edit what comes
from Aida64.
8-to show what edited at the end have to give
apply.
Show picture
novax1 has attached the following images:
This post has been edited 2 times, last edit by "novax1" (Dec 11th 2018, 1:21pm)
