• 19.02.2019, 04:22
Farbwerk and 3 EK Vardar RGB
Dienstag, 29. Januar 2019, 18:12
Hello All,
I'm planning a new system build and working on RGB, Fan control.
I have 2 x 360 rads each with 3 EK Vardar RGB classic fans.
Is it ok to connect 3 rgb fans using a 3 way splitter to 1 port on the Farbwerk?
It's been some time since my last build and it seems the rgb led everything has
exploded with so many options.
I would like some independent fan lighting control but this would require 2
farbwerk and possibly a 3rd for intake fans..
Also I have noticed the Pinout on the Farbwerk is 12v,B,R,G and most common RGB Fan's and Headers on Mobo are 12v, G,R,B
Blue and Green are reversed. Is there an adapter cable for this, I could probably make one but most of these cables are pre molded..
Any other options?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »jdpworks« (30. Januar 2019, 07:37)
