• 24.04.2019, 00:53
RGB fans: How do I control them with Aquaero?
Saturday, April 6th 2019, 2:18pm
I have 2 types of RGB fans.
One has 2 cables 1 for speed and 1 for light (Barrow RGB Multicoller PWM 120), but I don't know how I can connect them to the RGB header of the motherboard (Asus Maximus XI. I need a controller that can boost the signal as I don't think the MB can handle the lights on 6 fans, but the connectors are standard PWM female, not RGB, but with the steering pins, or whatever they are called, under pin 1 and 4, not under pin 1 and 3),
The other has 1 cable with a controller (Thermaltake Riing Trio 12) and I have no idea how to make the Aquaero control the fan speed.
