• 26.05.2020, 12:17
QUADRO Soft Sensor D5 NEXT Temp Issue
Friday, June 21st 2019, 3:36am
I am having an issue with my 2 QUADRO controllers. Right now, I have a virtual/soft sensor setup on each of my QUADRO’s to read the water temp from my D5 NEXT pump in Aquasuite. I then use the water temp to set the fan speed on a curve; which works perfectly… for a while. After a random amount of time, usually a few hours, the QUADRO’s spin the fans up to 100% and in Aquasuite, I can no longer see the Water Temp from the D5 NEXT when I look at the QUADRO sensor settings. When I look at the D5 NEXT settings, everything looks fine and I see the water temp there. This has happened a few times over the past couple days and the only thing that fixes it is to restart the computer. Everything is at the latest version/firmware.
Any Ideas?
Similar threads
