Sie sind nicht angemeldet.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Speedy-VI« (1. November 2022, 00:57)
I don't want to "accuse" anyone of anything, but I did ask "If the end user is not supposed to know what these values mean they why display them in the Status diagram?" I also pointed out that the word "membrane" is misspelled in an effort to be helpful. I still don't know why these variables are displayed or if they are meant to be interpreted by the end user because my inquiry was ignored. I suspect that if I sent my questions to AC support they would still be ignored. Perhaps I will try it.You have received an answer to your question, Aquacomputer is not obliged to document all values that are only used internally in the LEAKSHIELD.
What one could accuse them of is that the values that are not intended for the user are visible in the GUI. Why then should a further explanation follow?
We added them for our service and they show different pressures at the pump cycle and some calculated factors.
Thank you Stephan for providing some insight into what the values displayed in the LKS Status window mean. If I understand, you can measure and/or calculate the pressure on each side of the membrane, then use this information to calculate the permeability of the membrane. Once you have that, its trivial to display an alarm if the permeability is outside of an acceptable range. I am curious if the status indicator that you are going to add will be a simple alert that just indicates that the membrane is clogged or it if will provide a range of data. Either way it will be a welcome improvement because clogged membranes seem to be an issue for some users (below 1% according to AC).These variables are showing the behaviour of the membrane. We added them for our service and they show different pressures at the pump cycle and some calculated factors.
As some users (below 1%) have reported issues with clogged membranes we will add a nice status indicator in the near future and a warning when the membrane needs cleaning.
The membrane permability is measured by the pressure difference between the point the pump runs and after stopping the pump and waiting for equalization of the pressure of both sides.
